RS2 BBS LM's
  • pixsaudisex2
    • Sep 2004
    • 3110
    them 19s look fantastic..
    mine are just little ones...
    • fridtjov-audirs2
      • Jun 2005
      • 131
      • Country: Norway
      Originally posted by PaulJ
      Now that looks stunning, would consider these especially as summer wheels
      Hi Can you give me more information on these
      Are they LM 169, 8.5 x 19 ET50, Do they hit anywhere, What type and size of tyres are you using, Whats the ride like
      Thanks in advance Paul
      is 8,5 x 19 et 50 or 51 I need to check. I use 225/35 Michelin PS2.
      Ride is nice 225/35 is ok, but hit a little bit with 235/35.
      • PaulJ
        • Jun 2008
        • 253
        But still looks good !
        1995 RS2 Nogaro
        1971 Lotus Elan Sprint
        1974 Lotus Elan+2S 130/5
        • PaulJ
          • Jun 2008
          • 253
          I've done a quick autocad based on the wheel size, tyre size, diameter etc, offset
          does not take into account tyre stretch/squash
          17 x 7 ET55 with 245 tyre is roughly the same as 8.5 x 18 et56 with 245
          19 x 8.5 ET50 with 235 tyre, outside of tyre sits the same as above 2 above
          with inside of tyre 10mm towards the outside giving additional clearance
          diameter of the 19's are 20 mm larger with the tyre on
          Will have to have a look tonight and see if I can work out where it will be tight
          I'm guessing rear arches, front steering arm, arch liners when on lock,
          Keep the info coming
          Cheers Paul
          1995 RS2 Nogaro
          • PaulJ
            • Jun 2008
            • 253
            Hi can you tell me where the hitting occured
            Thanks PaulJ
            1995 RS2 Nogaro
            • fridtjov-audirs2
              • Jun 2005
              • 131
              • Country: Norway
              #21
              Thanks PaulJ
              rear outside
              • PaulJ
                • Jun 2008
                • 253
                Hi, Can you confirm the offset for me, 50mm is a BBS standard size
                but I suppose you can get other offsets, I take it the tyre clears the front
                steering arms OK
                Thanks Paul
                1995 RS2 Nogaro
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  #23
                  Digging this thread up again.
                  I have In offer for the 18x8.5 et56 BBS LM.
                  Question is: will they fit with 225/40/18? + 5mm front spacer and nothing rear?
                  Will they fit with 235/40/18 using spacers all around?
                  Is the better option 245/35/18?
                  Od like to know from people who have already tried them
