s8 Avus MK1 18" data needed
  • AndersS2
    • Sep 2005
    • 1364
    • Home: Norway
    Is there anyone who know how much there is from center of the rim to the inner wall in cm?
    I need a wheel with 21cm from center of rim to the innerwall.
    My LM reps only have 20,5cm but they do build up more than other rims I think
    Anders - S2 Avant Clubsport - 8pots or die!
  • europeanme
    • Oct 2005
    • 3817
    Give me a minute i will check my spare...
    just to confirm you are after the dimension from the wheel centre to the inner wall of the rim....
    i go now...
    • europeanme
      • Oct 2005
      • 3817
      it's not looking good for the s8's either....
      at the closest point straight behind the spokes it is the same 410mm diameter or 20,5 cm radially)..
      it does depend on how far behind the calipers sit into the wheel (towards the centre of the car)....as the wheel tapers out...
      how that helps...
      Mike
      • AndersS2
        • Sep 2005
        • 1364
        • Home: Norway
        how that helps...
        Mike
        aha, same as on the LM's. I noticed the walls there also tapers out further backwards.
        Well, then I see no other solution than a new bracket and a phaeton hat/adapter to accomdate for the inner wall which tapers out as you say.
        Phaeton hats/adapters for sale anyone?
        thanks for the measurements Mike
        • AndersS2
          • Sep 2005
          • 1364
          • Home: Norway
          how about the rs4 MK 1's?
          20,5cm there too?
            We did say you need Phaeton hat from day one Anders
            AndyP and Neo have brackets btw
            I think this was the same issue Terrybullwon had when he tried to use the RS4 discs
            • europeanme
              • Oct 2005
              • 3817
              no worries dude....
              stick with the S8's and get bambridge to knock you up some brackets to put a slight inboard offset...or space the calipers slightly to allow the fitting of the wheels you want....
              • AndersS2
                • Sep 2005
                • 1364
                • Home: Norway
                lol I know. Thats the downside of beeing stubborn.
                Then theres always the option of the r8 1 piece disc, or go 19". 19" are not an option really. Tried it before, did not like it.
                Btw, Mike, how is the clearance on the avus' further inn towards the center of car (imagine they are bolted up)?
                I will have to look around for some hats then (rs4 left, phaeton right) :
                cheers,
                • europeanme
                  • Oct 2005
                  • 3817
                  cheers,
                  after a quick visual measure, i think that you could got in by about 25-35mm and they should be significant clearance.....but as i haven't got everything (caliper, disc and wheel) in front of me, don't quote me....
                  are you running spacers on your avant?....i cannot remember if you said you were or not....
                  • Acidburn
                    • 13459
                    So whats it going to be, lm's or s8's?
                    • AndersS2
                      • Sep 2005
                      • 1364
                      • Home: Norway
                      Thanks Mike. That make sense, as others are running same wheels as me on 365 discs.
                      Both mate. and a third set too :mischeif:
