Is there anyone who know how much there is from center of the rim to the inner wall in cm?
I need a wheel with 21cm from center of rim to the innerwall.
My LM reps only have 20,5cm but they do build up more than other rims I think
Reason: human error
it's not looking good for the s8's either....
at the closest point straight behind the spokes it is the same 410mm diameter or 20,5 cm radially)..
it does depend on how far behind the calipers sit into the wheel (towards the centre of the car)....as the wheel tapers out...
how that helps...
Mike
Reason: extra info added
how that helps...
Mike
aha, same as on the LM's. I noticed the walls there also tapers out further backwards.
Well, then I see no other solution than a new bracket and a phaeton hat/adapter to accomdate for the inner wall which tapers out as you say.
stick with the S8's and get bambridge to knock you up some brackets to put a slight inboard offset...or space the calipers slightly to allow the fitting of the wheels you want....
We did say you need Phaeton hat from day one Anders
AndyP and Neo have brackets btw
I think this was the same issue Terrybullwon had when he tried to use the RS4 discs
lol I know. Thats the downside of beeing stubborn.
Then theres always the option of the r8 1 piece disc, or go 19". 19" are not an option really. Tried it before, did not like it.
Btw, Mike, how is the clearance on the avus' further inn towards the center of car (imagine they are bolted up)?
I will have to look around for some hats then (rs4 left, phaeton right) :
cheers,
after a quick visual measure, i think that you could got in by about 25-35mm and they should be significant clearance.....but as i haven't got everything (caliper, disc and wheel) in front of me, don't quote me....
are you running spacers on your avant?....i cannot remember if you said you were or not....
Thanks Mike. That make sense, as others are running same wheels as me on 365 discs.
