Old thread... but, maybe, someone knows, or has experience with fitting at the rear
R17 8.5J ET50 with 255/40 tires ??
those would be best fitment with the fronts (aka OEM) R17 7J ET55 with 225/45
I just have an option to purchase full set up like this, that's why such a question:
Tire Tech Information - The Wheel Fitment, Tyre Stretch, Rolling Radius and Speedometer Error Calculator, built on ISO 4000-1 and ISO 8855 standards. Play with specs, try different settings, compare results
Much better running a square setup IMO. Rolling radius is very close with what you are proposing, but even if it does not rub at the rear, I suspect it will push like mad (understeer).
