Does anyone know whether it would cause a problem to run slightly different F/R rolling diameters on a quattro? I'm planning on having 235/40/18 on the fronts and 255/35/18 on the rears. That'll make the rear rolling diameter 9mm less than the front. Doesn't sound like much but justed wanted to check I'm not going to **** anything up!
The only concern is the centre diff, as it is a torsen it is not advised , the sizes you have given only have a difference of 12 wheel revolutions per mile and will be OK but this is going to wear out the diff faster than normal .
If you use a 225/40/18 front instead of a 235 it will be fine with the 255/35/18 rear , that would be my advice .
Exactly what I needed to know Thanks for the advice.
Tom
Please don't think i'm just getting at anyone, but these cars understeer too much as it is!
More grip on the back than the front will only make this worse in my opinion
I'd go for 255's all round and put up with the added tramlining.
