front/rear rolling diameters
  • urS6Tom
    • 773
    Does anyone know whether it would cause a problem to run slightly different F/R rolling diameters on a quattro? I'm planning on having 235/40/18 on the fronts and 255/35/18 on the rears. That'll make the rear rolling diameter 9mm less than the front. Doesn't sound like much but justed wanted to check I'm not going to **** anything up!
    cheers,
    Tom
  • loxxrider
    • Mar 2010
    • 95
    you should try and keep it within 3%
    1010tires.com has a great rolling diameter calculator that spits out a percentage too
    FYI I've run 225 40 18 and 255 35 18 on my 200 20v with no problems
    • Thuppu
      • 4115
      265/35 would be almost exact. Can you fit it?
      • urS6Tom
        • 773
        It's within 1.4% so hopefully that's ok!
        Nah, it's an 8.5J wheel so 255 is the maximum that's safe I think
        • driftin jo
          • Sep 2007
          • 2222
          The only concern is the centre diff, as it is a torsen it is not advised , the sizes you have given only have a difference of 12 wheel revolutions per mile and will be OK but this is going to wear out the diff faster than normal .
          If you use a 225/40/18 front instead of a 235 it will be fine with the 255/35/18 rear , that would be my advice .
          • urS6Tom
            • 773
            Exactly what I needed to know Thanks for the advice.
            Tom
            • HMS-S6
              • Jan 2010
              • 1164
              Tom
              Please don't think i'm just getting at anyone, but these cars understeer too much as it is!
              More grip on the back than the front will only make this worse in my opinion
              I'd go for 255's all round and put up with the added tramlining.
