It's a lot of money to spend on something that's not going to be as sound as some wheels that are a direct fit. There are many style wheels that are similar to them and can be had in the correct fitment. I'm just posting my opinion as an engineer and experience on track; others may disagree and you'll have to make up your own mind. THe only thing that is certain is that it will cost quite a bit to get adaptors made up to suit your application.
Wheel Adaptors
I know you ver knowlegable on the s2's from your other threads etc. This is why I have asked the question, although I am also experienced ont the track and working on my own cars I have always had 205GTi's which weigh less than my right leg. lol also I have never thought about doing this kind of thing before.
Id rather have someone telling me the cons of a job over the pros. At least then I know that there are risks envolved etc.
Thank you for the help Rusty.
Will have to let the wheels go to somone else, £300 is hard to turn down though especially when LM replicas cost a wedge.
Oh well.Comment
Hey Dobby, ive always fancied a set of these myself, just waiting for a scabby set to come up to have a punt. Have a search, im sure it was an american site but, due to the construction of the alloy, its face and seat etc it made it possible to machine in another set of holes at 5x112. The cap then covers it off to make it look respectable.
No this obv weakens the wheel to a degree, but plenty of alloys out her with multi holes in them!
Would i take them on track, no. Would i cut about with them? yup.
Bloke done it on an Black A4 to help with your search. If you do go for it, let us know how it goes!
Just a thought
ALComment
Evening all, I'm not an engineer or an experienced racer and find this thread both interesting and fascinating.
One thing I would bring to your attention is, and I stand to be corrected if I am miles off the game, is that I was of the impression that Audis' own RS2 runs a pcd of 5x120, so if I have that part right would there be an inexpensive viable hub conversion available possibly sourceing parts from a salvage RS2.
If I am wrong then please excuse my nose shoving in but if I'm right I am just surprised nobody mentioned this before now.
Good luck Simon
StuartComment
Rs2 parts tend to be rare/expensive, dunno what all else needs to be swapped to run them, brakes etc.
Adding 5x14.3 m12 and 5x100 would open up a world of wheels, could be worth a look if ever doing all four wheel bearingsCurrent-2004 Impreza PPP wagon
Sold ABY-stockComment
If it was 5x120 then you'd be fine... but unfortunately, in this instance anyway, it's 5x130 (stock Porsche) and the hubs are different to the standard S2, especially at the rear, where not only are they off an avant (different to a coupe) but they also incorporate the Porsche drum handbrake. A select few have gone to the effort of fitting RS2 hubs on an avant and even fewer on a coupe but ultimately, it's more a labour of love than an upgrade. Oh, and the Porsche wheels are ET50 something too...Last edited by Rusty; 21 June 2011, 21:28.Cheers'en, AndyC
Ive just been around my mates house to look at the alloys against my car and they look sweet. I have been told there is a place in Hemel Hempstead that will drill alloys so when I have the money ill be taking a wheel over their to see what they think/advise.
I cant be bothered with a hub conversion etc, too much time and money really.
Just need to get the car running well now then ill be able to put pennies towards the wheelsComment
I stand corrected, thanksIf it was 5x120 then you'd be fine... but unfortunately, in this instance anyway, it's 5x130 (stock Porsche) and the hubs are different to the standard S2, especially at the rear, where not only are they off an avant (different to a coupe) but they also incorporate the Porsche drum handbrake. A select few have gone to the effort of fitting RS2 hubs on an avant and even fewer on a coupe but ultimately, it's more a labour of love than an upgrade. Oh, and the Porsche wheels are ET50 something too...Comment
@rusty I used 20mm hubcentric spacers on my avant with no problems whatsoever it's the pricks that run odd spacers with no spigot rings etc never torque wheels up then the wheel falls off and they twine till the cows come home!! Rant over as adapters can open up more than just Audi s8 alloys as an option. Don't get me wrong adapters and spacers will cause faster rates of wear on parts like wheel bearings etc but then so does everything once modified past manufacturers specification.Comment
yes, 205s are lighter than the front axle on an S2
and a mate has a track Golf (~205) that is so light at the rear, it can only just compress the 60lb helper springs on his coilovers...
