Will these wheels fit?
  • willg54
    • Jun 2009
    • 2055
    I've done a few searches but struggling to find an answer..
    Would 18inch x 8.5j ET35 fit on the front?
    and 18inch x 9.5j ET35 fit on the rear?
    If anyone know, please let me know!!
    1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
    1994 Audi 80 - 2.0 8v (slow but reliable!)
  • TimE-J
    • Jul 2009
    • 1292
    The 8.5 probably will fit on the front but may need a small spacer i.e 2-3mm and you would need to run 225 as I think anything much bigger will cause rubbing issues. Don't know about the 9.5 think they may be a little wide.
    96 S2 aby Coupe. Rebuild Project
    96 mk3 golf tdi daily.
    • Acidburn
      • 13459
      You'd at the very least need coilovers, think max i've heard on a s2 is dougs on 9x19's and from what i've read it needed arch and suspension work. if I still had my 9.5x19's you could have borrowed one to try, they are sitting in bahnstorm tuning in northampton so the new owner might lend you one to try on the car.
        Coupe yeah avant no
          If you don't mind some stretch then yes on coupe. On the front the issue is the steering arm ball joint which will rub the shoulder of the tyre, with 235s you will need a 5mm spacer. At the rear 8.5s with 235s fit easily so I reckon 9.5s would be no probs with a bit of stretch and maybe a spacer.
            Newsh is right you need ET30-32 for 8.5J alloys at the front so 5mm spacers
            • willg54
              • Jun 2009
              • 2055
              That sounds good to me! I've got 993brake bells on the front so that should help a bit too.
              When it's finally on the road i'll have to go try some!
              • zefsider
                • Dec 2011
                • 138
                if 5mm spacers only, what about the wheel bolts.? Would it need longer bolts or will 5mm extra width tolerate the standard length bolts without risking over stress ?
                • quattrodudes2
                  • Oct 2011
                  • 10
                  hi guys will 9.5s fit on a rs2 cheers quattrodudes
                  • JOSH,S ABY S2
                    • Jun 2010
                    • 109
                    I run 18x8.5 et35 all around and 225 tyres lowered on h&r springs and they are fine on my coupe. I've just ordered some 10mm spacers for the rear to bring them out to the arches.
                      Nope because of the rear upright
                      • willg54
                        • Jun 2009
                        • 2055
                        Trying to make a final decision on wheels...
                        The rears are my only uncertainty. They're 18" 9.5j ET35. running on 255x35x18 tyres but not sure if they'll fit. What do you reckon?
                          I am sure they will fit on the rear Will there is loads more space than the front. I have 245s on a 8.5j ET35 with a 3mm shim and there is laods room at the back
                          • willg54
                            • Jun 2009
                            • 2055
                            hahaha still can't decide!
                            I have nearly decided.. looking at 8j x 18 et42 and 9j x 18 et42 on the rear. I'm guessing I'll probably need 10mm spacers right?
