Any aftermarket wheel dealer will be able to supply the tapered bolts. I'd say you've been very lucky if you have been driving around with OE radius bolts in those Mille alloys I have the same wheels and they definitely require taper bolts.
Hmm, this is all quite odd. If the wheels and bolts have been on for 4 years, then chances are the bolts are ok, that's real odd.
This needs to be looked at properly to figure out what's up. The only temp. suggestion i have is to swap the bolts that keep coming undone to the back wheels and see what happens very carefully. Make sure you torque the wheel bolts too if you can. Can you post pictures of the wheel bolts and the hole in the wheel for the bolt to go through so we can see? also these adapters you had made, they have to be suspected now as well. Is it possible you can get some original Mille adapters and ask about what bolts your wheels should be using form an agent of Mille?
Martyn
It is odd for sure.
I don't have any wheel adapters - the Mile Miglias bolt straight on to the S2 hub, or do you mean the spigot rings to properly locate the wheels? They originally were blue plastic, but last time I took the wheels off to change the front pads, the plastic rings had split and they fell off. I got some metal ones made up to the same dimensions (measured off the rear rings).
Typically, the agent where these wheels were bought from is now out of business
I'll try and source some tapered bolts though.
I had my OZ wheel fitted by a so-called expert. In their infinite wisdom they made the following errors:
1. Fitted tapered seat bolts to a radius seat wheel.
2. Forgot to consider the bolt has to pass through the disk before it engages in the hub.
Net result: Only 3mm thread engagement (2 turns instead of at least 6 to 8) and damaged seats on my OZ wheels. I only noticed when I was changing pads a short while after I bought the wheels. This triggered me to do the stud conversion 2 years ago. I still run conical seat bolts in my radius seat wheels after I clicked the wrong item on the website when ordering. I remedied the situation with seat conversion washers. My lockers are from a scooby of all things.
I bought everything from www.trackstore.co.uk . My studs are 60mm long but check before ordering...don't forget to consider the thickness of the disk.
The reason why the end of your bolts look mullered Dan is the fact they protrude through your hub and get covered in crap. When you undo the bolt this rubbish gets pulled through your hub threads. Do a stud conversion as it not only makes life easier but also saves the threads in your expensive hubs.
Designun Limited....
I have had one customer who had his alloys fitted by a supposed specialist who didnt change the bolt type which means the wheel didnt fit properly and the bolts started to undo. I sold him the following parts.
Front brake pads, discs and callipers (as they scraped along the road when his wheel fell off at 40mph)
Front Suspension leg & hub (because the wheel bolts tore out when they are loose and the leg bent)
Front bumper wing and headlamp (when he veered out of control into a wall)
Basically I would take it very seriously because i think my customer was very lucky in the situation
I have a similar issue with RS6 reps. OE bolts are definately not long enough!!!
Does anybody know what the seat type is for these, as I bought them 2nd hand, and am unsure of the supplier / manufacturer???
( I will take a look later, but its not easy to tell the difference visually looking at the wheel )
Bit late. Hopefully the pic should give a better idea of radius/taper seat bolts.
The one on the left is an original oe radius seat bolt. The one in the middle is an aftermarket bolt for a taper seat. The one on the end is an aftermarket radius seat bolt. I think it it is easier to compare the two aftermarket ones.
Basically if the profile is V shaped it is a taper, if it is curved it's a radius.
