Loose nuts
Just got mine in the post this morning from trackstore.co.uk, looking forward to sorting this little problem out once and for all! will probably do it this weekend so that I can properly clean out the hub threads and do it right first time.
That kit on ebay is very good value, but I wanted a set of locking nuts which he's not selling, and he doesn't say how long the bolts are. Still worth a punt though if you want a stud conversion and don't mind ordering a suitable set of locking nuts from somewhere else.Ex S2 owner, now running around in an A4 Avant quattro...
Dan,Originally posted by dan_bBeen speaking to Trackstore, going to change the studs to 50mm, will be delivered tomorrow.
@Nick - what wheels do you have?
They are RS6 replicas - 18 x 8.5's with ET35 offset.
The wheels are OK except they foul the bolt for the mudflap on the nearside front - Oh well, my mate takes the piss for having flaps on a 'sports' car anyway.
50mm studs are spot on for these wheels.
Did you try one of the 60mm first? I'd hate to give you duff info for your particular wheels mate...
You could stuff a drill / pencil etc down one of the holes and get a rough idea of how long the stud needs to be to pas through the wheel, and still leave enough to bolt onto.
NickComment
Well, I've been running on my new studs for 2 weeks now, happy to report that all is well. Wheel wobble gone, brake juddering gone. Still got ABS and brake squeal issues, but they're separate!
Doing the stud conversion was very straightforward.
Took the old bolts out, gave the hub threads a very good clean out with Brake Cleaner, then a rag on the end of a screwdriver. I used threadlock on the hub-ends of each stud and screwed them in by hand. Re-mounted wheels (which is a total doddle with the studs in place) and I'm happy to say that the 50mm studs were perfectly long enough - there was sufficient thread engagement all round. New locking nuts installed too, so hopefully they should stay on there.
Had problems with only one hub thread which required two attempts to thread it in by hand, but all in all, easy peasy, and will make my life much easier for the forthcoming replacement of anti-squeal shims, bleeding of fluid (got 2litres of ATE Super) and locating the dodgy ABS sensor...
All in all, a top mod, very easy, and makes future wheel-changing scenarios straightforward. Has also cured my wheel securing issues. I'm wondering whether to take this up further with the garage who supplied me with what was clearly the wrong type of locking bolts when they lost the key from the previous set?Ex S2 owner, now running around in an A4 Avant quattro...
Yep - they were the equivalent locking nuts to the standards: they're all 60 degree seats. They've all got a 19Hex wheel brace pattern, so I had to get a larger jobbie from Halfords, but no big deal.Ex S2 owner, now running around in an A4 Avant quattro...
Nice one.Originally posted by dan_bYep - they were the equivalent locking nuts to the standards: they're all 60 degree seats. They've all got a 19Hex wheel brace pattern, so I had to get a larger jobbie from Halfords, but no big deal.
The ones off ebay are 45mm, not long enough for people with big brake conversions.Comment
