anyone seen these on an s2?
Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim
& 2 bar! Tags: None -
What are they?? Seat wheels?? I reckon they would look coolsigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm -
PCD = 5x100?
Same as some of the aftermarket stuff on the bay. Could get esact size, pcd and offset then... and 18"ers.
I'm umming and erring about wheels atm. Need to see some pearl weiss's with other alloys too. Superlegerras in anthracite are current thinking.
@S2 South West... where you to then. I'm in Brissle.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
i've got a pearl white and I looked at/considered the following:
Super T's 18's
S8 Avus 18's
S8 mirrored, later style 18's
Ronal r76(?) 18's look like a 6 spoke S2 Avus
BBS LM's (expensive)
BBS CH 18's
RS4 18's
i went for the rs4's in the end on the basis of looks and cost....£800 inc vat and delivery for the 18's with Toyo's
Cheers,
Davidsigpic
1992 3b S2 CoupeComment
Tom, im not sure what they are from, i found them on ebay, caught my eye because they looked a little diff to the norm, also said they fitted mercs.
Andy, im in plymouth, not many s2's down this way, only seen one other pearl, which is one i looked at buying but it was a dog.
when i can afford it im thinking about these
& 2 bar! Comment
Originally posted by s2_southwestTom, im not sure what they are from, i found them on ebay, caught my eye because they looked a little diff to the norm, also said they fitted mercs.
Yeh but the merc centre bore size is different and the S2 pcd is 5x112Comment
Most Mercedes are 5 x 112mm but the Offset is slightly different as well. Can't remember what it is tho'Originally posted by JamoYeh but the merc centre bore size is different and the S2 pcd is 5x112
DavidComment
If you can get Superleggera (and afford them!) I'd say go for it, they are very light indeed - and that's never a bad thing! I would have some if I knackered one of my Superturismos, wouldn't really be that bothered about the look of them either!
(Oh yes, and they must be easier to clean than my 16 spoke wheels - I've just bought a washing up brush to clean 64 teeth!)
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
The Mercedes-Benz wheels have a 67mm centerbore. The offsets range from 35mm to 45mm. Remember too that there are two different wheelbolt diameters. The wheels for the larger vehicles have the correct sized boltholes and are a conical seat for the bolt mounting. The wheels for the new SL are an 18 inch wheel, have the correct sized boltholes and have a 44mm offset. If I had a 5 x 112 hub instead of the 4 x 108 hub, I would be a spacer/hub adapter away from posting pics.Originally posted by Stick InsectMost Mercedes are 5 x 112mm but the Offset is slightly different as well. Can't remember what it is tho'
David
"Nulla tenaci invia est via"Comment
