anyone seen these on an s2?
  • s2_southwest
    • Oct 2004
    • 823
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • audiman
    • 4827
    What are they?? Seat wheels?? I reckon they would look cool
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
      PCD = 5x100?
      Same as some of the aftermarket stuff on the bay. Could get esact size, pcd and offset then... and 18"ers.
      I'm umming and erring about wheels atm. Need to see some pearl weiss's with other alloys too. Superlegerras in anthracite are current thinking.
      @S2 South West... where you to then. I'm in Brissle.
      Last edited by Rusty; 5 December 2004, 23:05. Reason: teh is not a f*****g word... again!
      • s2driveruk
        • 12696
        i've got a pearl white and I looked at/considered the following:
        Super T's 18's
        S8 Avus 18's
        S8 mirrored, later style 18's
        Ronal r76(?) 18's look like a 6 spoke S2 Avus
        BBS LM's (expensive)
        BBS CH 18's
        RS4 18's
        i went for the rs4's in the end on the basis of looks and cost....£800 inc vat and delivery for the 18's with Toyo's
        Cheers,
        David
        1992 3b S2 Coupe
        • s2_southwest
          • Oct 2004
          • 823
          Tom, im not sure what they are from, i found them on ebay, caught my eye because they looked a little diff to the norm, also said they fitted mercs.
          Andy, im in plymouth, not many s2's down this way, only seen one other pearl, which is one i looked at buying but it was a dog.
          when i can afford it im thinking about these
            Yeh but the merc centre bore size is different and the S2 pcd is 5x112
            • Stick Insect
              • Dec 2003
              • 2338
              Most Mercedes are 5 x 112mm but the Offset is slightly different as well. Can't remember what it is tho'
              David
              • Keeper of The Kitten
                • Dec 2003
                • 2317
                If you can get Superleggera (and afford them!) I'd say go for it, they are very light indeed - and that's never a bad thing! I would have some if I knackered one of my Superturismos, wouldn't really be that bothered about the look of them either!
                (Oh yes, and they must be easier to clean than my 16 spoke wheels - I've just bought a washing up brush to clean 64 teeth!)
                __MDC__
                Martin Cutting
                • A1QSHIP
                  • Aug 2004
                  • 975
                  David
                  The Mercedes-Benz wheels have a 67mm centerbore. The offsets range from 35mm to 45mm. Remember too that there are two different wheelbolt diameters. The wheels for the larger vehicles have the correct sized boltholes and are a conical seat for the bolt mounting. The wheels for the new SL are an 18 inch wheel, have the correct sized boltholes and have a 44mm offset. If I had a 5 x 112 hub instead of the 4 x 108 hub, I would be a spacer/hub adapter away from posting pics.
                  "Nulla tenaci invia est via"
