I thought I would share this experience as a warning.
I have RS2 calipers on the front and RS4 calipers on the rear of my car. I bought a set of 17" OZ racing wheels with ET35. These fit fine when I used 2mm spacers on the front. They clear the rear calipers with lots of space.
When I needed a set of wheels for winter tires, I went out and bought another set of OZ Racing wheels again with ET35. These are not the same model but the ET is the same.
Now comes the fun part. The wheels won't fit over the RS4 calipers in the rear! It looks like I would need something like ET 32 or 31 for this model to clear the brakes.
Here is the lesson: ET IS HALF THE STORY! It is only a measure of the backspace at the center of the wheel. The curvature of the wheel on the inside is the second factor in clearance. And it is never given.
In effect, you can calculate the correct ET's till you eyes fall out. The only way to be SURE your wheels will fit is to try them.
Think about that when shopping for wheels on Ebay.
