Warning - ET is half the story
  • 91_S2
    • 612
    I thought I would share this experience as a warning.
    I have RS2 calipers on the front and RS4 calipers on the rear of my car. I bought a set of 17" OZ racing wheels with ET35. These fit fine when I used 2mm spacers on the front. They clear the rear calipers with lots of space.
    When I needed a set of wheels for winter tires, I went out and bought another set of OZ Racing wheels again with ET35. These are not the same model but the ET is the same.
    Now comes the fun part. The wheels won't fit over the RS4 calipers in the rear! It looks like I would need something like ET 32 or 31 for this model to clear the brakes.
    Here is the lesson: ET IS HALF THE STORY! It is only a measure of the backspace at the center of the wheel. The curvature of the wheel on the inside is the second factor in clearance. And it is never given.
    In effect, you can calculate the correct ET's till you eyes fall out. The only way to be SURE your wheels will fit is to try them.
    Think about that when shopping for wheels on Ebay.
  • dan_b
    • Sep 2003
    • 3670
    Have you been able to take the rims back?
    • 91_S2
      • 612
      I can't. I bought them on Ebay. But it looks like 4mm spacers on the rear will get the job done. Damn, more costs.
      My general rule of thumb for 7,5x17 or 8x17 wheels is now that the ET should be around 31 if you have big brakes and want to be on the safe side.
      • batty
        • Jul 2004
        • 81
        what about buying wheels with a greater offset - say ET45, as fitted to A4's, & A6's - then using 8mm spacers to 'correct' the offset. This would guarantee 8mm more caliper clearance than the wheel design intended.
        I have another reason for this way of thinking - that is the missis has an A4 and if/when I buy new wheels for the S2, they could also fit the A4 if needed.
        • GlynRS2
          • Dec 2003
          • 307
          I agree entirely. I discovered the same when I fitted Seat Ibiza Cupra R 4-pot Brembo 304mm brakes to my Corrado G60 a couple of years back. The Seat kit runs on exactly the same hub etc. and the Ibiza Cupra R came with OZ 17" Superturismos with an ET of 35. I had BBS 17" RXs also with an ET of 35, but needed an 8mm spacer from South Coast Wheels to get clearance from the spokes ot the wheels
          It is all in the wheel design and how far outboard the spokes are which is quite seperate to the ET, which is just a measure of the offset of the hub in relation to the centre line of the rim. Interestingly BBS RCs, which looked virtually identical to RXs gave much more space for brake callipers with the same ET of 35mm and therfore didn't need a spacer.
          So when looking for new wheels and you have big brakes the best option is to get the correct ET but look for a design that gives plenty of space for the calliper - generally that means the outside face of the wheel will be inline with the outside edge of the rim or in the case of the Porsche Cups on my RS2 dished out from that point - just remember then you have to kerbs a wide berth or it could be expensive
          Glyn
          Ex-Polar Silver RS2
          Sprint Blue RS4 - new toy :mischeif:
          • dan_b
            • Sep 2003
            • 3670
            I don't think you can really go wrong with Porsche- copied wheel designs, given that all the Porsches have such big calipers anyway so the wheels are designed to accommodate those, and apparently to provide a good airflow to the calipers too - built in cooling from the wheel design?
            • Lee
              • 1512
              Oh yeah. Gotta check the spoke positions! With my OZ Vela rims I can get away with very shallow brake bells which make them more structurally sound and cheaper to manufacture. MY brake brackets are also very slim at 28mm thick. I noted that some of the Porsche brackets were nocking on for 50mm thick. There was some method in my maddness when selecting my rims.
              Designun Limited....
              • Keeper of The Kitten
                • Dec 2003
                • 2317
                The makers of brake calipers (all of them) can provide profile drawings, and it's true that wheel manufacturers generally don't (though some, OZ included, can provide generic profiles for specific wheel types if you ask nicely - these show the spokes and curvature into the rim area for particular forgings - bear in mind that wider wheels are often from a different tool).
                It's a problem that needs to be overcome on any race car, often on touring type cars with limited mods allowed (the same sort of situation most road car folk encounter as they don't tend to make new uprights or anything twee like that), but I must admit I am surprised that wheel profile catches people out so easily! Make a cardboard template of the inside profile if you have the wheel, then you can draw onto a caliper profile, or convert to CAD and do it that way.
                If you're buying the wheels and already have the brakes, good luck!!!
                I agree with the idea of using a bit more offset to allow the fitment of thicker spacers, not too much of course, but paper thin spacers don't sound like a good idea just as much as over thick spacers. I reckon about 5mm is fair for a spacer. Don't forget, you can get wheels machined down if they stick out a bit, but you can't put the metal back when it's gone, only space it back.
                Dan, talking about built in cooling, do you remember the days when Porsche raced on BBS wheels and used those (now illegal) cooling vanes to pull air out of the wheel?!!! They were a bit like a vented disc mounted on the outside. I always thought it was funny that they had the spoke design marked on them to replicate the wheel underneath...
                I don't think the shape of the wheel Porsche use will have a huge effect, though having said that the top part of the wheel locally travels twice as fast as the car while it rotates.
                __MDC__
                Martin Cutting
                • 91_S2
                  • 612
                  __MDC__
                  Hehe. Good luck indeed. The problem is that the alternative of buying wheels first and them going out to find brakes that fit is not too much fun either.
                  I disagree about the spacers. I tend to feel that thin spacers are better than thick spacers since you don't have a long foreign element extending the bending moment of the wheel axis. But that is just me.
                    • Dec 2003
                    • 2317
                    Hi there 91 S2!
                    Yeah, it's always going to be a problem getting parts from two different makers (brakes and wheels) to fit with a third manufacturer (Audi!), so it's not easy whichever way you do it...
                    Yes, long spacers are very very bad! I wouldn't personally recommend much more than the 5mm I mentioned earlier, and it would be better if they were made as an interference fit to either the hub or the wheel itself (top hat profile), making them more of a unit part. However I think that a very thin spacer is prone to damage and could possibly cause a wheel to not be seated properly.
                    Better to avoid spacers altogether if you can, and if you use them either make out of steel (say, en16t/24t) or better quality aluminium (HE15TF or similar) - preferably with a bit of surface treatment for extended life. I'd definitely use steel for thinner spacers if you want to put higher mileage on the car!
                    I'm lucky, I have wheels with a generous amount of space behind the spokes, and being 18" they will better accomodate brakes that fit inside 17" rims, as the spokes don't curve over into the rim for about an extra 1/2"
                    Just need to save up for the brakes now...!!
                    __MDC__
                    Martin Cutting
                    • Lee
                      • 1512
                      At the end of the day the bolts do not take any bending moments if installed correctly. The bolts will be in pure tension. It is the friction at the high preload faces that are the load paths. So long as you can achieve a high enough torque to give a high preload. I would also favour a sefter material for spacers such as aluminium to give a better friction joint. The most important consideration is to have a proper boss location in the centre of the wheel: this disappears if the spacer design is rubbish.
                        • Dec 2003
                        • 2317
                        Fair points there Lee about surface friction, but I'd agree that it's the boss location you refer to that is key - hence my earlier reference to making a top hat profile, which can fit to the hub or the wheel. Often, wheel centres have a steel insert, which is potentially favourable if you choose to make a new insert with a spacing flange integrated?
                        Options for ensuring a positive fixing would be to lock the spacer with drive pegs (maybe ring dowels in the mounting holes, if the spacer is attached to the wheel) or with wheel mounting studs (spigots, not the threads!) going through the hub flange and spacer (and to retain the spacer firmly you can put a couple of CSK screws in to fix it to the hub).
                        On race cars you rely heavily on drive pegs for a positive lock between hub and wheel due to the single nut "centre lock" design. Not to be taken lightly though, broken drive pegs can and do result in lost wheels, even with nut retaining sprags!
                        In your case, with custom aluminium disc bells, you can choose the thickness you need and integrate it into the bell, which I'd guess is what you've done anyway?
                        __MDC__
                        Martin Cutting
                        • Lee
                          • 1512
                          Sure did integrate the required spacer thickness into the bell. But since doing my brakes I decided to fit 255/35R18 tyres up front meaning that I had to shove a 3mm spacer in. If the bolts pass through the wheel, spacer, brake bell and into hub then I think that any other retention device is pretty redundant other than aiding servicing (stopping bits falling all over the place). My bells were made from Al2618 which is a material you should be familiar with in high end motorsport. At £1000 per mtr of billet, bells can get expensive pretty quickly if the thickness starts increasing too much. There is a conflicting need to try to keep the bell as slim as possible for cost reasons. Not putting too much thickness into the brake bell also allows configuration flexibility wince a slim spacer can be removed if necessary.
                          Large spacers can also be acceptable if the spigot location is there. I would favour these, as you state, to me made from steel or at least with steel thread inserts. And then separately bolting the spacer to the hub and providing a set of threads for retaining the wheel. These need to have a minimum thickness due to the convoluted load path introduced.
                          In a race car application a single centre nut will see bending moments. Totally agree in this context.
                          • Lee
                            • 1512
                            On a kind of similar note. If you lose preload on a single wheel bolt, the other 4 will loosen pretty quickly too. It was a problem we used to have on Spacecraft bolted joints if the implementation was not optimal.
                            • dan_b
                              • Sep 2003
                              • 3670
                              This I discovered myself this year with my incorrect profile locking wheel nut - 1 nut radius, the other 4 (correctly) were tapered... Scary stuff loose nuts.
