Tyre Blowout
  • JP
    • 1858
    Originally posted by Rusty
    Hub to strut boltwouldn't tretch bolts and have a defined tightening torque or 90Nm for M12 as for M14 (IIRC) with a 90deg angle to do the stretch. I found this out at the Nuerburgring
    Almost no garage in the world would know this, neither would they know that Audi recommend to replace the stretch bolts and that the Audi workshop manual states not to take them apart in the first place but to remove the driveshaft from the hub instead and separate at the lower ball joint... oh and then replace the retaining bolts on them too
    So... if they just tweaked them, then they can come undone. I'll put money on the fact that they didn't even fit new nylocks though, which is just sloppy on a 20 year old car
    Hubs to struts were never undone. Which is the only thing that can cause that can close the gap.
    Only ball joints and topmounts which wouldn't effect the tire to strut clearance.
    After discussing the issue with lagz the only things we could put it down to is not having the car tracked after swapping said suspension parts. Which although a bit naughty to not get it done straightaway still shouldn't have changed the clearance from previous as the struts to hubs where never undone. Although inadvertently anyone tracking it would most probably not replace said bolts/nylocks.
    Or the fact that there are two different tire models on the same axle where one tire model most likely has a slighty wider section width (cross section profile) than the other resulting in the reduced clearance. Which I would assume to be the more likely issue. Interesting that there is reported blowouts on the particular tire in question too where we may find that the blow out happened first through weakening from potholes and then subsequently caused the rubbing?
    UrS6 Stroker + HTA3586 =
    • andy10v
      • 5996
      Originally posted by lagz33
      Have been running with the spare since, now the other front wheel has gt a every so slight dent on the inside of the alloy (F***ING POTHOLES) losing 10psi a day so can run whilst I sort a remedy.
      Therefore I am now done with low profile tyres, heard about these banded steel wheels, then have come to the conclusion to just buy some normal steels dont want to end up with another blow out because they are too wide!
      Would these fit ok?
      http://www.ebay.co.uk/itm/GENUINE-SK...item4ab37fc6ae
      I get a bit thrown with the offset business :S am also going to get the suspension strut looked at as the tyre guy thinks it must be that....
      Edit: The compatibility checker on the listing says it wont fit but not sure if that is accurate
      Why not just get a set of stock 16" avus wheels if you want 16"? Better width as well.
      Sold ABY-stock
        I run 16" avus like that. Tyres are cheap, as they're fitted to everything, and the ride is a bit better but handling suffers. At least they're pretty light so performance is nice and sharp. Got the back wheels slipping in 2nd the other day... must have been slippery for sure.
        other option is to run 225/50R16 instead of the 205/55R16 and maybe add a 5mm spacer in to improve clearance and stance.
