spacer advice?
  • 1781cc
    • Nov 2011
    • 1253
    spacer advice?
    Hi guys, I will be getting my B3 back soon - running properly and with a few upgrades, the only issue being that the RS4 rep alloys have about 2mm clearance, so spacers are the way forward.
    I am looking at getting 8mm spacers front and rear to create more clearance and improve stance. My only question is where it comes to longer wheel nuts.
    Do I go for 40mm or 50mm wheel nuts? I am not sure what the stock ones are, but I guess they are about 35mm (or am I lying? lol)
    Any advice greatly received as I need to get these on the car for tuesday and need to order today
    Thanks
  • Rusty
    • 18953
    A few points & questions:-
    • Quoted length is the thread length, IIRC, that's 25mm on a stock wheel bolt - you need to add the spacer width to the length and then go for the nearest size that's no lower than that. I prefer a bit of stick through as a safety net.
    • You need to make sure that the wheel still seats correctly on the centre hub boss with an 8mm spacer, much more and you may be looking at hubcentric spacers.
    • Depending on whether the wheels are genuine or aftermarket, you need to find out if they need radius or taper seat bolts.
    • The B3 has smaller wheel arches than the B4, so most of the S2 rules of thumb won't really apply.
    • What is the offset (ET) of the wheels and the wide (7.5J / 8J)
    • How much room is there between the edge of the wheel and the inner wheel well?
    • 1781cc
      • Nov 2011
      • 1253
      I agree totally, I am not set on 8mm spacers, but that was my guestimate of a size, maybe a 5mm will be safer, thus reducing the length, if the stock bolts are 25, then the 40s should be ok?
      lost me a little there, but I was thinking of these:
      http://www.ebay.co.uk/itm/Eibach-Pro...item4847b75f63
      Aftermarket ones, bolts are radius I think as they taper down from the nut to the thread, but are then a consistent size through the thread length to the end
      yup, this is what the wheels look like on at the moment, without spacers, there is a slight rub when braking hard at the front where the shock compresses and touches the top
      ET38, 7.5J
      sorry mate, what part do you mean by inner wheel well? turning the wheel or in the front position?
      sorry, I am probably being dumb
      • Rusty
        • 18953
        £38 per spacer Speak to bambridge.
        Looking a those pictures and your comment that the tyres rub the arches, spacers are just going to make things worse. You need to get the correct size tyres tyres really for the B3 shell. What are they at the moment? B4 takes 225/45R17 but on a B3 you may have to go for a 205/50R17 off an early to mid noughties Mondeo.
        If the wheels rub the arches at all then that's very sub optimal, as you'll end up damaging something.
        • 1781cc
          • Nov 2011
          • 1253
          Hi mate, I wasnt going to buy those specifically, but those were the eibach type I was looking at - I will drop bambridge a line after I have given this a little more thought.
          I think I need to lift the car on the ramps and see where things are going astray, but I know that I am certainly not going to throw away £400 worth of rubber, so worst case they end up on the B4 and I have to get me some B3 alloys with a better fit.
          I might need to look into some arch modification or inner skin modification to make these fit, I really want them on the B3
          thanks for your advice and pointers
          Lee
          • Sleeper_Avant
            • 2372
            couple of things i noticed putting spacers on mine:
            check the taper on the wheel bolts, no.1 priority!
            i put a 3mm and 5mm on the front of mine and with tapered bolts i got about 5 or 6 full turns on the bolts, anything over 4 is perfect
            if there is any paint where the wheel bolts fit, rub it out with sandpaper as this cracks, rubs away and the bolts come loose, has this happen a couple of time with new build gpA STi`s and it was the thin paint and powdercoatings disintegrating, easy thing to check but saves loosing a wheel.
            and with 8mm spacer you no longer have a lip for the wheel to centre itself onto (on the hub)
            hope this helps bud
            1993 URS4 Avant Emerald Green 350+bhp
            1991 Ford Sierra Sapphire 4x4 in Magenta
            BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
              Radius (curved seat) bolt on the right, aftermarket taper on the left.
                Another pic of radius and straight taper.
                • gripper
                  • Jun 2008
                  • 1156
                  +1 I agree
                  I did not realize B3 arches were that small !
                  Kev@bambridge will sort you out with hubcentrics AND the right length wheel bolts It make take a while though as I had to wait for mine as there is not much call for 4x108.
                  By comparison I have 7.5x17J wheels with an offset of 33
                  Add to this 15mm front and 20mm rear hubcentrics on 215x45 tyres.
                  Wheel sits perfectly in the arches and nothings fell off yet !
                  For what this cost me so far I could have bought an S2
                  • 1781cc
                    • Nov 2011
                    • 1253
                    f*ck f*ck f*ck... I picked up the B3 today and dropped the B4 off for some electrics work... and guess what? the B3 scrapes and crashes all over the place with the wheels on, sounds like the tyres are scraping the arches and furthermore, there was a chronic vibration through the car above 40mph.
                    Anyway, I went back and put the winter tyres on the B3 from the avant (15s) and the 17" RS4s on the B4 - neither car objected!
                    So, a lot of decisions have been made for me, I am keeping the B4 estate now, its inherited the 17s and they will stay there... so its going to be an S2 replica - full steam ahead!
                    The B3 will keep the winters and I have a set of 15" cabrio wheels for the summer - at least its more sleeper looking this way!
                    Thanks for the advice guys, I will probably use what you guys have suggested to get some spacers on teh B4 for a better stance anyway, so no loss and I learnt something new.
                    • Rusty
                      • 18953
                      As said at the beginning, just needs the right sized tyres...
                      • 1781cc
                        • Nov 2011
                        • 1253
                        as said at the beginning, I ain't gonna scrap £400 worth of new Vredesdens...
                        • Rusty
                          • 18953
                          Who said anything about scrapping them? If you can use them on another car then do that or sell them on here.
                          Anyway, my point was that you can still use that design of wheel on your car of you fit the correct size tyre
                          What was the original wheel size on your B3?
                          • GazzaG60
                            • 4133
                            so lee. is it close to the arch or touching all the time.
                            on my coupe I had 8x18 et 35 with 235 tyres and no catching at all.
                            whats the general consensus on sizes for a b3 then. is it the arch volume or the lack of the flair that's the issue.
                            id be up squit-street if I cant fit 17" rims minimum for my 6 pots
                            • Rusty
                              • 18953
                              B3 saloon is different to the facelift coupe and B4.
                              From a quick search,
                              B3 was 205/50R15 = 586mm rolling diameter.
                              B4 was 195/65R15 & 205/55R16 = 634.5mm rolling diameter.
                              225/45R17 are 634.4mm rolling diameter.
                              You need to limit the width to 215mm and rolling diameter to roughly that of the original.
                              For 17" wheels:-
                              590mm (desired rolling diameter) - 17 x 25.4 (rim diameter) = 158.2mm sidewall.
                              For a 205 tyre - 158/205/2 ~ 40 profile, thus 205/40R17 tyres are what you need, based on the OE size. I remember when these were fitted to every car running 17s
                              The other option is to get the B4 arches on the car and a facelift front. I have seen this done before and 225/45R17s run on a B3 with 20VT conversion.
