Performance drop- wheel size
  • stocious
    • Jul 2012
    • 838
    Not knowing anything about rolling radius and all that, but hasn't the point of contact with road moved further away from the centre line of the drive, other words the lever from drive to road is longer?
    Plus the added weight !
    Or I did me sums wrong
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
    • gripper
      • Jun 2008
      • 1156
      Originally posted by driftin jo
      A stock 205/55/16 has the same rolling radius as a 225/40/18, well its less
      than 1% so as little as to make no difference.
      Not quite correct.
      A smaller wheel will cover more revolutions than a larger wheel over a given distance.
      Larger wheels will increase the gearing and decrease the acceleration a tad.
      It was for this reason I never put 17's on my RS2000 back in the day as it blunted performance with no other change to the setup !
      For what this cost me so far I could have bought an S2
        Don't forget that the rim size means nothing without taking the tyre width & profile into account
        So the rim size may be bigger but the tyre profile is smaller so the overall radius is barely changed.
        A 1% change in rolling radius will not make a noticeable difference. Weight the real factor here.
        • driftin jo
          • Sep 2007
          • 2222
          Originally posted by gripper
          Not quite correct.
          Yes it is, totally correct.
          • stocious
            • Jul 2012
            • 838
            Does AWD multiply the effect?
              • 12431
              I wouldnt have thought so, as has been said maintaining a similar rolling radius is important and minimising the unsprung weight. So putting cheap 18" wheels is likely to make it worse as they will weigh more than the 16" wheels and tyres.
              Take a look at sticky from wheel and tyre forum http://www.s2forum.com/forum/showthread.php?t=14910
              • 220bhp
                • 2578
                • Home: United Kingdom
                #22
                In my case there was very little in the overall hight between 16x50, and 18x40. so Ican only put it down to the fact that the heaviest part of any tyre is the tread.So it must be a case of rotational mass with the tread at the end of the wheel ,so to speak
                causeing the lack of acceleration,then after a certen speed intriea takes over
                Whatever it made a noticable differance to my car.
                • Tonybolony
                  • Dec 2011
                  • 636
                  The 'Tyretraders' website (Please don't ask me to post a link) gives a Tyre Size Calculator, so you can check that the upgraded wheel/tyre combo will give the same circumference as the original.
                  I'm sure we all know that increasing the circumference will give the same effect as a longer diff- Dulling acceleration, and braking- but not altering the in-gear RPM/Road speed readings. Rev counter readings against Speedo won't alter.
                  Indicated 70mph will be 75/80/85......... depending on the difference from original.
                  My Avant has 225/40-18's which are only 1 or 2% different from the original 16" Avus.
                  If the tyre circumference is the same as the originals, then your'e gonna have difficulty convincing me that the additional 1.5" radius of the wheel will dull the performance to the point that you will actually feel it.
                  • driftin jo
                    • Sep 2007
                    • 2222
                    The difference between a stock 205/55/16 and a 225/40/18 is only 0.8%
                    like I said earlier, not worth thinking about,
                    A brand new to worn tire will vary on diameter by 2% at this size!!
