Not knowing anything about rolling radius and all that, but hasn't the point of contact with road moved further away from the centre line of the drive, other words the lever from drive to road is longer?
Plus the added weight !
Or I did me sums wrong
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
A stock 205/55/16 has the same rolling radius as a 225/40/18, well its less
than 1% so as little as to make no difference.
Not quite correct.
A smaller wheel will cover more revolutions than a larger wheel over a given distance.
Larger wheels will increase the gearing and decrease the acceleration a tad.
It was for this reason I never put 17's on my RS2000 back in the day as it blunted performance with no other change to the setup !
For what this cost me so far I could have bought an S2
Don't forget that the rim size means nothing without taking the tyre width & profile into account
So the rim size may be bigger but the tyre profile is smaller so the overall radius is barely changed.
A 1% change in rolling radius will not make a noticeable difference. Weight the real factor here.
Not quite correct.
I wouldnt have thought so, as has been said maintaining a similar rolling radius is important and minimising the unsprung weight. So putting cheap 18" wheels is likely to make it worse as they will weigh more than the 16" wheels and tyres.
In my case there was very little in the overall hight between 16x50, and 18x40. so Ican only put it down to the fact that the heaviest part of any tyre is the tread.So it must be a case of rotational mass with the tread at the end of the wheel ,so to speak
causeing the lack of acceleration,then after a certen speed intriea takes over
Whatever it made a noticable differance to my car.
The 'Tyretraders' website (Please don't ask me to post a link) gives a Tyre Size Calculator, so you can check that the upgraded wheel/tyre combo will give the same circumference as the original.
I'm sure we all know that increasing the circumference will give the same effect as a longer diff- Dulling acceleration, and braking- but not altering the in-gear RPM/Road speed readings. Rev counter readings against Speedo won't alter.
Indicated 70mph will be 75/80/85......... depending on the difference from original.
My Avant has 225/40-18's which are only 1 or 2% different from the original 16" Avus.
If the tyre circumference is the same as the originals, then your'e gonna have difficulty convincing me that the additional 1.5" radius of the wheel will dull the performance to the point that you will actually feel it.
