I was at silverstone yesterday, just for a quick afternoon session, when my front-left tyre decided to pop off the alloy whilst powering through Woodcote
The disconcerting this is i'm not sure why, and as i'm heading to Spa in a few weeks i thought it might be worth comparing notes and seeing if anybody else has had this happen, or even if it's just likely down to chance.
The tyres were Toyo R888 semi-slick track tyres and were 32psi all round whilst cold. They are 225/40/18 so fit the 18" 7.5J alloys correctly and are correct for the load and speed ratings.
The front-left was fully loaded up under cornering at WOT when it went.
There appears to be a section of the side-wall which has a split in it, but as i nursed the car back to the pits after the incident rather than having the session red-flagged, i'm not certain what damage to the tyre was caused by dragging it half way around the lap, and what might have caused the seperation.
I suppose my lines of thinking for reasons are:
I need to get the alloy checked out to see if it's ok to use, it looks to have sustained some minor "kerbing" but that's it. Quite surprising really, it could have been catastrophic!
I missed out on lots of time on track after the incident and it was clear my track-time was up, but luckily no serious damage or incident caused so we just fitted my full-size spare alloy (unfortunately with Kumho road-tyre) to make it home. All good
- Incorrect tyre pressures
- Centrifugal force caused by the grip of the tyre and the weight of the car cornering at high speed and at full-power
- Damage to the tyre perhaps caused by something on track or scrubbing under the arch (there was a noise under tight cornering)
- Degradation of the tyre caused by almost 2 hours of track-action
(Just to be clear, I'm NOT talking about road tyres BTW)
