Tyre Popped Off
  • Lloyd
    • Apr 2006
    • 1559
    #31
    Originally posted by mcandmar
    I dont understand the tyre pressures you guys are talking about. For 225/40/18's i would have said 36-42 depending on the weight of the car, anything below 38 on my avant and it goes all soggy and sits on the sidewalls like the above pics. Its just not drivable like that. 20psi is a flat tyre
    Ahem! We're not talking about road tyres used on the road.
    RS2+ (now sold...)
    • martinws
      • Oct 2008
      • 917
      I think they are getting at the fact the pressure increases a lot on the track so they should be slightly lower than normal road driving so when they heat up at the air expands the pressure is perfect.
      You are lucky to get off so lightly. I guess the lower the profile tyre the easier it would be to control a blow out.
      • mcandmar
        • Apr 2004
        • 5118
        Oooh
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • benntenn67
          • Jun 2009
          • 859
          ... Slow puncture probably to blame - Glad there was no real damage
          Audi S2 Coupe 1995
          VW Passat GL5 (hatch) 1986
          VW Passat GL 1.8 (saloon) 1986
          Carrera Subway 8
          • Ross
            • Aug 2005
            • 3399
            You got off lightly... next time your rubber pops off you might end up with a massive bill 9 months later
            Low pressure looks like the cause then, and you've discovered another in-car display to add to the collection of useful information...
            • DJones
              • Jun 2005
              • 2020
              Tyre pressures really are a strange science, both my boys now race karts, (hence no new ur upgrades , I thought running a ur was expensive.. )
              Anyway learnt loads on tyre pressures, I used to think higher the pressure the better and sent my eldest out on 20 psi, came in tested pressure and got a reading of 30psi hot. Tyres (8" slicks on rear, 5" slicks on the front) were completely grained as they had over heated massively.
              Anyway spoke to one of the guys at the track and he said send him out on 10 psi cold and you want them coming in at about 13psi,the transformation in grip was out of this world but took longer to come on due to the low starting pressure.
              I appreciate its not an S2 but still works its tyres hard enough at 80mph to require bead retainers to hold them on the rim as without them they push the tyre off of the bead resulting in pressure loss to start with and coming off of the rim later.
              Food for thought, but pressures are critical when on a track day..
              • s2driveruk
                • 12696
                i had track day rubber on my s2 at ADI and being in a rush just set the pressures to the normal car tyre pressures i run which is about 35-36psi. On the V70a track rubber, it was like driving on ice (ciaran may well remember the laps) came in, let the car rest up, dropped the pressures and went out again...night and day, all the grip was back and you could push on...
                1992 3b S2 Coupe
                  • 12431
                  Just a thought, do they make extra load track tyres aswell? Normal road tyres for S2 are higher load rated
