Custom BBS RS split rims UrQuattro fitment
  • jsws3
    • Apr 2012
    • 1174
    I have a question .
    I have a set of bbs rs 16"x8 et24 with a 1" outer lip but would like bigger outer lip would I need to change the barrel as well as the lip to keep them 8j
    • dirtybarry
      • Jun 2006
      • 282
      Originally posted by Sküll
      wait, im drawing
      the mounting face is in the same place as before, by adding the 2" lip, you moved the centre of the wheel towards the outside of the wheel
      1986 urquattro 20v 3b
      • Skull
        • 3506
        • Country: Slovenia
        Audi Quattro WR
        • Skull
          • 3506
          • Country: Slovenia
          Or am i wrong?
          Audi Quattro WR
          • dirtybarry
            • Jun 2006
            • 282
            Can't argue with that.
            I must have got mixed up somewhere, your drawing does make sense.
            • Skull
              • 3506
              • Country: Slovenia
              #21
              now i you got me thinking...
              the centre of the wheel is moved just by 1" towards the mounting face, not 2"
              1" is 25,4mm, so 35-25,4=9,6mm
              so it is still positive, but et9,6
              baaaaahhh i go get a beer
              Audi Quattro WR
              • dirtybarry
                • Jun 2006
                • 282
                Your gonna love this, I just found my original working out and the actual offset is et 9.6
                I worked it all out in mm and converted it into "'s.
                Here goes,
                Centre of a 7" rim is 88.9mm
                + 35mm offset = 123.9 mm from inner edge to mounting face.
                Centre of 9" rim is 114.3mm = total rim width of 228.6mm
                228.6mm -123.9mm = 104.7mm outer lip to mounting face distance.
                So 114.3mm - 104.7mm should = the offset of 9.6mm
                Would love someone to clarify this
                • dirtybarry
                  • Jun 2006
                  • 282
                  Originally posted by jsws3
                  I have a question .
                  Yes you would need to change the barrel width to keep them 8j. If you went for a 2" lip your barrels would need to be 1" narrower to keep them 8j.
                  Fat is good
                  • jade
                    • Jan 2005
                    • 1811
                    • Home: New Zealand Current: Spain
                    #24
                    I have a set Of the same wheels but with et 24 so what would the biggest lip I could use 2.5" ? or could I go bigger
                    RS 2 580HP
                    • dirtybarry
                      • Jun 2006
                      • 282
                      A link showing that these radinox lips can be used as a cigarette lighter, also ways handy when you have ran out of gas
                      • dirtybarry
                        • Jun 2006
                        • 282
                        one more
                        • Skull
                          • 3506
                          • Country: Slovenia
                          #27
                          Depends on which car you want to use them on.
                          Since your et is lower, you cant use lips as large as with higher et.
                          Audi Quattro WR
                          • jade
                            • Jan 2005
                            • 1811
                            #28
                            Yes Thats what I thought, I will be using them on my SWB Sport, I am looking for a 3" lip on a 9j or 10j
                            RS 2 580HP
                            • jade
                              • Jan 2005
                              • 1811
                              #29
                              So if I do not need to worry about my arches what's the smallest ET I can run ? and what affect does negative ET have ?
                              RS 2 580HP
                              • G60Rallye
                                • Dec 2006
                                • 1321
                                It depends on which drivetrain set up you will be using ur quattro or S2? SWB arches will easily cope with a 3" lip. 10" overall is also easily possible. You couldn't go much more before it was getting too close inboard to the front steering arm.
