Wheel Hub Studs for RS2
  • Wheel Hub Studs for RS2
    Hi,
    Thx for a great forum that has been really useful when fixing my original brakes for my RS2. I got the calipers refurbed, new antisqueel shims, new pads and disks and the brakes are as new now. I could not have done it myself without the help from this forum.
    My problem now is that I had one wheel nut that was totally stuck and unable to remove without dammaging one of the studs on the left front wheel. The stud is so dammaged it's beyond repairs. Audi dealer don't have a serial for the stud and claims I have to change out the wheel hub, but for me it looks like it's possible to refit a new stud. The only thing is that I dont know what to buy since there is no serial for it.
    I'm thinking it might be from Porche and it could be ser # 993341671.
    http://www.design911.co.uk/fu/prod13...4-928-964-993/
    Anyone who can help me out ?
    Also, how do I get the stud out of the wheel hub without damaging the hub in the process. I tried knocking on the stud with a hammer, but it will not move. I didn't want to hit any harder. Maybe some heat will help me out?
    Thx in advance !
    Do you mean a wheel bolt stud. For really stubborn wheel bolts i use a metre long 3/4 inch drive breaker bar with hardened socket.
      No, I mean the studs coming out from the hub where the wheel nuts goes on. The stud is allready dammaged and needs to be replaced. I had to use a drill to get the nut off and that is why I also dammaged the stud.
      Thx!
        Then it would need removing and taking to an engineering shop.
        Alternatively the cheapest option may be a new hub carrier.
        I take it the threads are too damaged to chase the threads?
          The threads are too dammaged I'm afraid. I'm not sure if a new hub comes with the studs in place. On http://www.vagcat.com/epc/cat/au/RS2/1995/41/52/469989/ the scematics of the hub shows no studs. On the brakedisc however I can se the bolts on the drawing, but there are no serial for it. If I only knew what kind of stud have been used, I could refit one myself without having it taken to a advanced machinery shop I think.
          Thx!
            Just hit harder and it will come out.
              Ill look on etka for bolt size foryou.
                I'm afraid of bending the hub.
                Thx!
                  Any photos of your problem ?
                    Yeah, photos would help. I'd imagine it needs to be pressed out as opposed to hit.
                      If you can access the back of the stud you you could use a big G clamp and a socket/tube bigger than the head of the stud to press the stud out, that way you dont hammer the wheel bearing.
                      Like this but with a tube instead of a fork
                      Sold ABY-stock
                        This seems like a good idea Andy. Thanks for the tip. I also looked at youtube where some americans are hammering them out with a 3 lbs hammer. Just doesn't feel right for me. Currently my wheel is on, so photo will be later when I got the proper stud to fit the hub (if I ever get the right partnumber for it ) My MOT is deadlining this month. I doubt I will get this fixed in time with ordertime, xmas and everything. I just find it strange that the Audi dealer can't be more helpful.
                        Thanks!
                          That's the idea Andy.
                          It's very far from ideal but you can cheat the MOT with a missing stud by gluing a nut in there, well you can in the UK, I've encountered it quite often when working on Hi-Lux's and L200's etc.
                            You'll need a stud extractor.
                            The studs are threaded
                            Mike
                            http://www.s2-audi.co.uk
                            • #15
                              I think you are wrong about that.
                              Thanks!
