Azev Type-A
  • Kiku
    • Aug 2010
    • 497
    Azev Type-A
    Does enyone know or have opportunity to weight Azev type-A deep dish 17x8.5 and 17x10 wheels?
    1990 2.2 20VT Audi Coupe Quattro
    *Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
    1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmos
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    like these?
    TWINCHARGED power,zero lag
    AEM W/M injection
    • A1quattro
      • Jul 2006
      • 791
      hi i have BORBET asev A 17x8.5j 11kg with out centre cap
      • Kiku
        • Aug 2010
        • 497
        quattro-nick - Almost, the ones a guy offered me for sale where like very deep dish. 8.5 wide was like half the cigarette pack and the 10 wide well the whole pack got lost in it.
        A1quattro - you mean, borbet type a right? i ques they are the same ~11-12 kg each and the 10 wide wheel i ques is about 15kg.
        • Tonks4x4
          • Nov 2005
          • 3062
          Azev A 10x17 ET20
          10.924 Kg with a metal type valve and no centre cap.
          Tonks4x4 - The Land Rover Specialist
          Audi Nut!!!
          • A1quattro
            • Jul 2006
            • 791
            yes mine are borbet type a . looks same as asev i did have 15 now done to 8 after 10years rallying
            • Kiku
              • Aug 2010
              • 497
              Splendid Tonks! Thanks for the info. Quess I will buy them and put them under coupe.
              10 and 8.5 wide 4x108 17" azev are rear enough to just buy them!
              • 1781cc
                • Nov 2011
                • 1253
                I am running Brock B1s 8.5J and 10j on my cabby, its on the limit of legality, but they work well, car will look sweet with the Azev's - post piccies when you get em
                • Kiku
                  • Aug 2010
                  • 497
                  I was just thinking that will 10 wide on the back of the car be toooooooo wide.
                  Well last summer i ran bbs avantgardes but they ware way too heavy 12.7 was piece i think? Looked good though but car moved like 2.0l "hunday"....
                  Only BIG question is that what will i do about the tires since the car runs all four wheels and the hight has to be the same how wide the tires are doesnt make so big difference right? Any ideas?
                  • Kiku
                    • Aug 2010
                    • 497
                    Boing. As said before 17x8.5 and 17x10 both ET20. Im thinking of changeing those 10 wide to 8.5 if i can find that pcd and size because 10 wide for quattro i think will be too much of an overkill....
                    • Tonks4x4
                      • Nov 2005
                      • 3062
                      10" wide is too wide for the coupe...
                      Audi Nut!!!
                      • 1781cc
                        • Nov 2011
                        • 1253
                        But if you go with some "stretch" you should be able to fit the tread under the arch, my cab is running 10J on the rears and will work much better when its lowered:
                        Now:
                        And this is the same wheels on a cab, but lowered:
                        • Kiku
                          • Aug 2010
                          • 497
                          OMG... the one you have under coupe is 5x112 17x10 et20 right? Tire 245/40?
                          Okeiii thats fun then i quess 8.5" et 20 is the limit? Tire 215/45 or 225/45? I would prefer 215/45 since the front 8.5's might rub when the road is pumpy and you have to make a turn or smth?
                          • 1781cc
                            • Nov 2011
                            • 1253
                            FYI - on my pics both cars are running 235s
                            • Kiku
                              • Aug 2010
                              • 497
                              Since the roads arent good in Estonia im afraid i have to pass that 10" even with streched tire. You said that your cab isnt lowered. Are factory cab and cq(s2 ABY springs) about same hight?
                              Lee you have a side/front picture of your cab?
