Azev Type-A
Looks good.
Now i have to think will or will i not lower my coupe...1990 2.2 20VT Audi Coupe Quattro
*Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmosComment
There is 5 mm difference between a 215/45/17 and a 235/45/17 which is 0.8%, in theory you could get away with that. Personally I wouldn't run odd size tyre's on a quattro unless there was no other option, would 225/45's all round not work?1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
235/40 not 45 but the % is still 0.88. I think 225 will be very hard to put on a 10j wheel...
And since right now i dont have lowering suspension but i think i will install something during the summer, right now i have ABY springs. And 225/45 with e20 and 8.5j wheel at the front will def rub.1990 2.2 20VT Audi Coupe Quattro
So has enybody an idea will that 5mm difference on tire heights do harm or not?1990 2.2 20VT Audi Coupe Quattro
Sorry, I meant there was 5 mm difference between a 215/45/17 and a 235/40/17, not a 235/45 which is 18 mm bigger.
You should be OK with a 5 mm difference as it's within the wear range of a new tyre, that said I would measure the circumference of the tyre's you want to use to double check. I've seen over 10 mm variation between tyre's the same size but by different manufacturers so when you start using odd sizes there could be much more difference in real life than there is on paper.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
I`ve got Azev A 17 x 8,5" in my Coupe. One wheel without tire was about 11,5kg. Tires are streched Toyo 205x40
Ok well i got 2.5mm difference if i put 215/45/17 front and 245/40/17 at the back. So now my question is, is 245/40 too wide for cq when its lowered only a bit not 40/60 or smth? Will it rub?1990 2.2 20VT Audi Coupe Quattro
