Right, I know 225/45/17 is the best match in size to the original 205/55/16's and is the accepted size to use when up grading to 17" rims.
Not being a fan of wider than necessary tyre's I purchased a new set of 215/45/17 Toyo R1R semi slicks for the 17" x 7" wheels I was planning on fitting for the summer, though I've been running the car on stock wheels for the winter. In the mean time without trying the Toyo's out properly I picked up a set of 17" X 7.5" Compomotive's, which acknowledging the general consensus I fitted with 225/45/17 trackday rubber, a pair Avon ZZR's and a couple of Yokohama A048's.
Fitted the Compomotive's and was instantly impressed with the amount of grip, however they're a little noisy especially when cold and have a tendency to pick up on heavy white line's and banding etc, not badly but noticeable. Obviously the ride is also a fair bit harsher as well but I expected this and didn't find is as a bad as anticipated.
Anyway as an experiment I thought I'd better at least try the other wheels with the Toyo's expecting the ride to be worse what with there being less side wall. However this is not the case at all, the ride is miles better and the tendency to 'tramline' is gone completely, have to say it feels pretty much perfect.
I don't really get it, the rims are the same off set, both around ET30, the Compomotives are 0.5" wider but I can't see that making much difference and the tyre's are all similar in construction. The Compomotives weigh 20.5 kg's with a 225/45 and my other wheel's come in bang on 19 kg's with the 215/45.
I'm going to fit the 215 Toyo's to the Compomtive's next week and see how they feel.
I'm so impressed with the 215/45's Toyo's that if anyone fairly local like AndyC or James want to come for a blast and try them out their welcome to.
Your welcome to whack my wheels on your car so you can do direct comparison with your own set up.
Know a great place for some Bara Brith washed down with tea made with soft welsh water. I think i just gone to heaven!
I had 215s on 8,5J rims, and there was just a little sign of a healthy stretch.
