225/45/17 Vs 215/4517 ?
  • K Simmonds
    • Dec 2007
    • 7637
    Right, I know 225/45/17 is the best match in size to the original 205/55/16's and is the accepted size to use when up grading to 17" rims.
    Not being a fan of wider than necessary tyre's I purchased a new set of 215/45/17 Toyo R1R semi slicks for the 17" x 7" wheels I was planning on fitting for the summer, though I've been running the car on stock wheels for the winter. In the mean time without trying the Toyo's out properly I picked up a set of 17" X 7.5" Compomotive's, which acknowledging the general consensus I fitted with 225/45/17 trackday rubber, a pair Avon ZZR's and a couple of Yokohama A048's.
    Fitted the Compomotive's and was instantly impressed with the amount of grip, however they're a little noisy especially when cold and have a tendency to pick up on heavy white line's and banding etc, not badly but noticeable. Obviously the ride is also a fair bit harsher as well but I expected this and didn't find is as a bad as anticipated.
    Anyway as an experiment I thought I'd better at least try the other wheels with the Toyo's expecting the ride to be worse what with there being less side wall. However this is not the case at all, the ride is miles better and the tendency to 'tramline' is gone completely, have to say it feels pretty much perfect.
    I don't really get it, the rims are the same off set, both around ET30, the Compomotives are 0.5" wider but I can't see that making much difference and the tyre's are all similar in construction. The Compomotives weigh 20.5 kg's with a 225/45 and my other wheel's come in bang on 19 kg's with the 215/45.
    I'm going to fit the 215 Toyo's to the Compomtive's next week and see how they feel.
    I'm so impressed with the 215/45's Toyo's that if anyone fairly local like AndyC or James want to come for a blast and try them out their welcome to.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
  • K Simmonds
    • Dec 2007
    • 7637
    Haven't tried the Toyo's on the Compomotive's yet, but here some pic's with the light weight wheels fitted. I'm wondering what set of four 225/45 Toyo R1R's would feel like, I ca get them trade price now for £76 a pop.
    1994 MTM RS2.
    2000 B5 TQS.
    • re2500
      • May 2007
      • 2185
      Mmmmm, tasty rubber! We'll have to arrange a blast soon bud, when the weather is nice...
      "Difficult is worth doing"
      • re2500
        • May 2007
        • 2185
        Ive always wondered about the differences between the performance of those two tyre sizes, when i originally bought my CQ it was fitted with TSW imolas (not to different to your multispokes) and it was fitted with 215 45 17's and it handled well/looked good on them...
        I now run 225/45/17 on my BBS's just because theyre the "default" 17 size for the s2.
        would 215 be too narrow for my 8J BBS's? i doubt it as many of us run 205's on 7.5 avus's...
        • K Simmonds
          • Dec 2007
          • 7637
          Yeah, now the weather's getting better that would be cool Your welcome to whack my wheels on your car so you can do direct comparison with your own set up.
          A 215/45 will mount on an 8J rim but there maybe a touch of the dreaded John Inman stretch. That said in my ignorance the tyre's I first purchased for the car 7 years ago were 205/45/17" Toyo T1R's as I got a super deal (£250 fitted) on a brand new set. At first I had them on an 8J rim and the stretch didn't look silly, they were however completely the wrong size and looked too small for the car.
          The 215/45 Toyo's sit really nicely on my 7J rim's and don't look too small for the car, on the rear I use an 8 mm spacer giving ET 22 to get them to fill the arches better.
          I'm undecided now what I'm going to do, it maybe that the R1R's are a better tyre for road use and I'd be happy with a set of them in 225/45 on the Compomotives. There again maybe I should try a set of 'normal' tyre's like Conti's or Dunlops in the wider size. However it's a lot of hassle getting the 215's on and off the wheels so I'd rather not have to do it unless I have too.
          1994 MTM RS2.
          2000 B5 TQS.
          • K Simmonds
            • Dec 2007
            • 7637
            Well, considering a 205/60/15 is a standard factory size for B3 CQ's and that size gives a diameter of 632 mm compared to 625 mm with 215/45 I'd say 215/45's or 225/45's are right, depends on what you prefer the feel of realy
            1994 MTM RS2.
            2000 B5 TQS.
            • re2500
              • May 2007
              • 2185
              Likewise you could try my 225 45 17's? They're directional Goodyear Eagle F1's, so might make an interesting comparison.
              Ive just swapped back to my 17's this weekend, as i was running 205 55 16 ContiWinterContacts on the avus's over the winter. I have to say although they're a bit wobbly, i prefer the ride on the 16's and it tramlines much less on them...
              It sticks like stains to a mattress with the Goodyear 17's but theres not much compliance in them when combined with my relatively stiff suspension.
              • K Simmonds
                • Dec 2007
                • 7637
                Would be an interesting experiment as my set up is pretty unforgiving as well, poly/solid alloy bushes and solid compbrake top-mounts combined with standard springs.
                Bizarrely with the 215/45's my car feels more like it does on 205/55/16's than on 225/45/17's, no tram-lining and the ride is good, nowhere near as crashy over bumps as with the 225/45's.
                Most weekends are good for me mate, got plenty of building on during the week so I can afford to take them off again.
                1994 MTM RS2.
                2000 B5 TQS.
                • K Simmonds
                  • Dec 2007
                  • 7637
                  I'm going to leave the 225's on my Compomotives for the time being as those mulitispoke rim's are a major PITA to get tyre's on and off especially one's like R1R's with very stiff side wall's. The 225's weren't too bad to fit on the Comp's, the Yoko's being easier as they have softer side walls, the Avon's appear very similar in construction to the Toyo's.
                  As I'm quite capable of doing it myself and it's not cheap paying someone else so I rather use the machines where I used to work which are pretty antiquated so a great deal of care is required to avoid marking the rims, hence leaving the R1R's put for the time being.
                  Anyway my point was if you wanted you could also give the Compo's a try with my current track day rubber.
                  1994 MTM RS2.
                  2000 B5 TQS.
                  • re2500
                    • May 2007
                    • 2185
                    Tbh, im more curious about the 215 R1R's as they seem a reasonable price and i could be tempted to venture back to 215's when the F1's are worn... I run winter tyres in the colders months anyway so could be tempted by a more performance dry biased tyre mfor the summer...i'm doubtful i'd ever fit dedicated track rubber, dont do enough track days tbh.
                    We'll have to work out a date when the sunny weather comes when i can pop up.
                    We can go up into the depths of wales and terrorize some sheep...
                    ...with our cars! they may be on the road you see...
                    • andy10v
                      • 5996
                      If you are comparing different tyre models/brans as as well as sizes then side wall stiffness will also make a massive difference to comfort/handling.
                      16 v 17 make a massive difference to steering response/feel, but also grip/comfort depending on the road surface. My dad and I tried driving the same road, then swapping wheels. On the smooth bits the 17s felt soo much nicer, more connection with the road, so precise etc, however on some poorer surface the car would "skitter" on the 17s, whereas the 16s would just squidge over it and keep gripping (or so it felt). Also noticeably better acceleration with 16" wheels.
                      Sold ABY-stock
                        • 4754
                        Sounds like my idea of fun doing some serious driving on the welsh roads. Wll be up that way in a couple months and can't wait to enjoy them sheep lined roads in one of our audi,s Know a great place for some Bara Brith washed down with tea made with soft welsh water. I think i just gone to heaven!
                        • K Simmonds
                          • Dec 2007
                          • 7637
                          16 v 17 make a massive difference to steering response/feel, but also grip/comfort depending on the road surface. My dad and I tried driving the same road, then swapping wheels. On the smooth bits the 17s felt soo much nicer, more connection with the road, so precise etc, howevander on some poorer surface the car would "skitter" on the 17s, whereas the 16s would just squidge over it and keep gripping (or so it felt). Also noticeably better acceleration with 16" wheels.
                          Andy, I hear you my friend, the tyre's themselves can have a large bearing on performance and feel.
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • BLAMM0
                            • Aug 2010
                            • 337
                            • Country: Lithuania
                            the 215 simply look better on narrow rim (7-8J), ant they tend to flex less, so there's no movement when cornering I had 215s on 8,5J rims, and there was just a little sign of a healthy stretch.
