Konis....I am happy with full hard front and half hard rear. Konis are crap though and they have definately gone off in the 9 months they have been on the car. Wouldn't buy again....need something with a remote resevoirs as I am cooking them on a cross coutry blast and they are definately being affected. Don't change your Konis until you have fitted new rubber. They make a massive difference to ride especially if your current tyres have stiff sidewalls.
Bridgestone or Toyo? & Koni Settings
Now that Lee has had his say, several times :mischeif: Only kidding as agree with most. Koni on three cars have been fine
S2 coupe koni
Pirelli P9000 good tyre under rated lasts Ok wet lacks feel dry
P zero rosso good dry never really trusted in wet average wear
RS2 standard suspension @ 80k
Sportconti 2 excellent but had to go as 245/40/17
RS2 koni 1 click from stiff IIRC
S03 so far so good. Like the wet weather performance esp under braking. Dry experience limited wear 5mm all round after 5k/6 months
Mixed driving but no track days yet.Alastair
RS2Comment
Originally posted by Dr HMine were Conti Sportcontact not the Sportcontact 2 and when I changed to Toyos I personally felt the car handled a lot better, especially in the wet. It used to feel really vague and twitchy round corners with the contis, like it was going to let go at any minute
Oh well, how boring would it be if we all agreed!
My bad, they are the 2's.
For me I am using the car day to day more in all weathers so need something thats decent in wet and dry conditions. Also I want a decent amount of wear from them also. Most of the time I have a few blasts where I can driving to work but there is usually too much traffic and then some fun when the roads arent so busy. Mostly driving along B and A roads ranging from crap tarmac with pot holes and mud all over the shop to smooth newish roads and occasionally dual carriageway and motorway.Originally posted by LeeWhat are you after Greg? Dry grip, wet grip, predictability, value for money, etc How do you drive? What surfaces do you most drive on? Do you give it beans occasionally or every day?
I think i will try the Bridgestones this time around and then try something else next time.
The suspension is defintely set too hard though, I will fit the new tyres and take it from a spin before I do the brakes and suspension and see how it is then.
GregGreg
Only complaint I had with Pirellis were the ones I tried. I cannot offer any comments on the P9000 cos I haven't tried them. P6000 came with the car and they were in the bin within a couple of weeks. I was not suggesting that all Pirellis were crap but that I couldn't comment on the Pirellis and Avons as the models I had used were aweful. Greg, don't think you will go wrong with SO-3s, SportContacts or Toyos. They are all good tyres. All I am trying to say is you cannot get a firm opinion unless the contributor has tested the exact models you are considering and can form a subjective assessment. Saying that one is the best without even trying the other is not reliable.
I have played around a lot with the konis to get a setting I like. I ignored 'advice' from so-called specialists and found that their recommendations were not optimum for me. So Greg, if you need them softer make them softer.....Can't remember which way they turn now to tighten as it has been some time. The next time they come off the car they are in the bin anyway.1995 S2 Avant with some upgrades
Designun Limited....
Aerospace, Space and Motorsport Design Consultancy and hardware supply.Comment
Greg, the setup I've been given (by Wab) for the konis was to turn the adjusters all the way _out_ then the fronts in one full turn and rears in half a turn, I have the fronts set like this and they are superb, the rears accidentally got set to 1 and 1/2 turns in and they're too hard, make a slamming noise over bumps, I'll be adjusting them back a turn soon.
I'm on stock springs, if you are on harder springs you may want to go 1/2 a turn harder than me.
FWIW I like a controlled but comfy ride
in my old age
All the way out is softestComment
I have Conti SC2 and like 'em. Can't compare to much anything because these are the first ones. Second ones coming up - the same kind as I see no reason to change brand. They're quite round edged, you know, I don't know the tems. This makes them quite comfy and not so agressive as sharper ones like my friend's Nokians, they're NRY I guess.
Noise level is reasonable. Size 225/45-17.-Comment
Cheers John,Originally posted by newshGreg, the setup I've been given (by Wab) for the konis was to turn the adjusters all the way _out_ then the fronts in one full turn and rears in half a turn, I have the fronts set like this and they are superb, the rears accidentally got set to 1 and 1/2 turns in and they're too hard, make a slamming noise over bumps, I'll be adjusting them back a turn soon.
in my old age
I will try softening them because on bump roads the car gets thrown all over the shop because they are too hard at the moment. Which direction is it to wind them out though. Clockwise or anti clockwise. Sounds daft I know but the diagram you get with the konis shows arrows in both directions which is no use.
GregGreg
I am running 245/40/17 Toyo's and can confirm IMO that they are WAY better in terms of feel and comfort than the Pirelli P-Zero's that were on when I bought it. In fact I am on my third pair of Toyo's. (very similar to Yokohamas in my view....)
Cheers.
Steve.The Perfectionist
Yep anti clockwise for full soft and then turn in from there.Comment
cool, cheers john. Ive ordered a set of S03's now so I will have those to fit at the garage meet. in the morning before i fit my brakes and shocks I will see if i can get on the brake and suspension tester to see how they are performing at the moment too.
GregGreg
Just as a heads up - Toyo Proxes T1-S is not going to be available for much longer, has been replaced by a cheaper tyres T1-R I think it's called.
I saw some GoodYear Eagle F1 GDS2s for sale today in a tyre shop - I was surprised as I thought they'd been replaced by the GDS3s - outwardly they have a visably different tread pattern. I had GDS2s on my previous car, but have GDS3s on the S2, don't know how they compare back to back.
I understand the Bridgestone S0-3s are inferior to the SO-2s but have no personal experience of this myself:I found the S0-2s to be superb tyres, shame you can't get them anymore.Ex S2 owner, now running around in an A4 Avant quattro...
