Hi all, just seen some wheels for sale and I'm very tempted as long as they will fit. I have a 3 b coupe withe original alloys but they have corroded so much I often have pump up the tyres cos they leak around the rims. I would like to get Porsche cup 3 alloys, but do they fit straight on? The rears are 9j x17" and the fronts are 7.5 j x 17" . Will these fit ok? Thanks
Wheel fitment question
Tags: None
If they're Porsche fitment they won't fit.Comment
I have seen Porsche wheels on the s2 before. Have they also replaced the hubs to accommodate different PCD ?Comment
Porsche wheels tend to be in the ET 45-55 range with a PCD of 5 x 130, Audi S2 wheels are ET 37 with a PCD of 5 x 112.
So there is room of hub adaptors if you pick the right offset/width wheels.
Alternatively you can get get good copies of the Porsche rims in 5 x 112 with the correct offset which is probably the more satisfactory solution as staggered size wheels and quattro isn't a great mix unless you have a very good reason for doing so and in that case you'd most likely want the wider ones on the front.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
Ok thanks, does anyone have a set they would sell or something similar? I'm eventually going to get bigger calipers so 17-18" is a must. Thanks all.Comment
