215/50/50 quattro tyres
  • hmg
    • May 2014
    • 28
    I'm looking at getting a new set of tyres for my u987 ur Quattro.
    Having had a quick scan it seems that the Dunlops 215/50R15 Dunlop SP Sport 9000 Tyre are getting very very scarce now!!!
    Is there any other alternatives out there or has anyone got a link to a tyre seller that still has stock and doesn't want to pull my pants down and beat me senseless.
  • robo
    • Aug 2004
    • 2086
    Go for 205/50/15 with XL and high speed rating.
    [/B]
    sigpic_________
    Rob
      I've always used 225s on my ur.
      • robo
        • Aug 2004
        • 2086
        This is what I have on my ur but next time will go for 205's. Mate of mine has them on and the car looks good plus tyres are cheap and can be replaced more often.
        sigpic_________
        Rob
        • chris
          • Jan 2008
          • 365
          ur tyres
          Bill Smith , church road garage , baschurch , shropshire , had some in stock recently, worth a try,,
          • hmg
            • May 2014
            • 28
            I think the early Quattros had 205s but later cars speedos were calibrated for the wider wheel/tyres.
            Don't the 205s look a bit skinny ??
            • quattrodave
              • Dec 2008
              • 218
              The early UR's had 205/60x15 on 6J rims note thats 60 profile not 50 so if a 215/50 is fitted to the later 8J rim on an early car (analogue dash) then the speedo is around 5% out, did Audi ? recalibrate the speedo on later cars or not, if not then at a indicated 100 its only doing 95.
              • hmg
                • May 2014
                • 28
                I'm pretty sure the speedos were re calibrated by Audi for the increase in wheel size to 8J
                • hmg
                  • May 2014
                  • 28
                  Thanks for the heads up Chris Bill had 2 sets
                  These must be the last two sets available unless Dunlop do another run ,which is debateable.
                  I've been looking for months for these.
                  Two vey happy ur quattro owners
                  • quattrodave
                    • Dec 2008
                    • 218
                    Hmm,
                    Increase in wheel width 6j - 8j on later cars, actually decrease in rolling diameter 205/60 on early v 215/50 on later cars so if I fit 215/50 on mine the speedo reads fast by at least 5% with 225/50 its out by around 3.5 %. I used 225/50 on my later 8j rims when I fitted them.
                    • hmg
                      • May 2014
                      • 28
                      I like this little gizmo
                      Tire size comparison the easy way. Use our tire size comparison calculator to compare diameter, width, sidewall, circumference and revolutions per mile.
