wheel spacers
  • martinjs
    • 3205
    Ok, i'll take a look then.
    martin
    • curlyks2
      • 1069
      Originally posted by Beetie
      Yeah it needs to be something like that but it looks like the flange is smaller than the 56/7mm? that is standard on the hub.....
      Inside diameter of hole at back (after initial bit) = 56 or 57 mm.
      Outside diameter of flange at front = 56 or 57 mm.
      The MTM part number for the pictured ones is MTM10011255715 which I think decodes to (does make a lot of sense, but this is not an official part number decode):
      MTM100 base part number
      1125 Hole layout - 112 x 5
      57 hub/flange diameter
      15 spacer thickness
      Ck.
      Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
      • martinjs
        • 3205
        Yeah the bore size is 57mm, but we cant use a flange like in the pic above because a 5mm spacer doesn't sit proud of the hub. The above one is 15mm right?
        martin
        • curlyks2
          • 1069
          Originally posted by martinjs
          Yeah the bore size is 57mm, but we cant use a flange like in the pic above because a 5mm spacer doesn't sit proud of the hub. The above one is 15mm right? martin
          Yes the one(s) in the picture(s) are 15mm. Shame they don't suit your application - best of luck with finding something to fit.
          Ck.
          • Sweeper
            • 1317
            • Country: Latvia
            #20
            Try www.****ech-shop.de
            I have 20mm spacers and the part number was SF 06/03 12120 20mm.
            I believe 121'20' means 20mm
            Vadim.
            New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
            • Beetie
              • Oct 2003
              • 1517
              Yeah the shop said 10 or 15mm was the least thickness to allow the flange but i didnt know if there was another way of doing it?
              Was a '93 3B, Dont ask now tho......
