Spacers and Wheel bolts
  • Pearl White Rob
    • Sep 2015
    • 38
    Hi all,
    I bought in error a lovely set of audi speed lines (the fake split rim type) that are for the 90 so have a ET45 offset. I have a CQ 20v with aftermarkets which don't appeal to me so was looking to change. The tyres on these are now at the end of there life so I want to sort the wheels out.
    To account for the 8mm offset difference of an ET37 Wheel I need to get some spacers, 10mm is fine, but can anyone tell me what length wheel bolts I'll need? or will standard ones still be ok at this small offset?
    Many Thanks,
    Rob
    You will want longer bolts. Measure your stock ones and add the spacer size to it.
    From memory the stock ones are M14x1.5 x 27mm
    • Pearl White Rob
      • Sep 2015
      • 38
      Wheel Bolts
      Just measured the bolts are the sizes you mentioned. Im adding 10mm so il probably go for 40mm bolts as they will be easier to find than 37mm!
      Many thanks
      Rob
      • Sonic
        • Jul 2006
        • 5514
        10mm spacer and 40mm bolts will be ideal.
        S2Forum.com Administrator
          Make sure you get the correct radius seat
          • Pearl White Rob
            • Sep 2015
            • 38
            Seat
            Is it 60 degrees? Il have to get the protractor out on the original bolts!
            Cheers!
            Rob
              On oem wheels it is a curved (radiused) seat not a conical one
              • A1QSHIP
                • Aug 2004
                • 975
                Might be a good time to consider a stud kit in place of the wheel bolts. If you are changing wheels & working with different spacers you only have to buy one set of mounting hardware.
                Chris
                "Nulla tenaci invia est via"
                • Pearl White Rob
                  • Sep 2015
                  • 38
                  So if I get bolts with a curved radius i should be alright then shouldn't I. As it will pull up where it needs to go.
                  • Sonic
                    • Jul 2006
                    • 5514
                    Yes that's right - 40mm round bolts NOT tapered.
