hi the evos have 114.2 pcd ,we are 112 has anyone on here fitted any evo wheels on there ur/s2 poss by drilling /fitting new steel inserts to give correct 112 pcd
evo wheels fitment on audi
Should be the answer for you. Wheel pcd adaptive or wobble wheel bolts.
1990 2.2 20VT Audi Coupe Quattro
*Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmos -
Yep I have my hubs drilled to take both stock Audi and 114.3 pcs rims so 10 holes in total. Means you don't need to mess with weird studs.
Sent from my LG-H955 using TapatalkComment
That's the way it should be done, I don't like the idea of those wobble bolt's though I guess they'd do the job.
A1quattro...what style Evo wheels do you want to fit ?1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
I have been looking for a spare audi 16/17 " magnisuim wheel just to save some weight , cant find any cheep audi but lots of EVO wheels hence my thoughts of poss useing them . but as its just for a spare welst rallying I would use the wobble bolts [never seen them before ] I cant have 2 sets of holes in hubs as ive cut metal out so they are flower shape now
this side of the water, there is a guy called jim green.
He is a very knowledgeable nice guy.
his very well built 90q (around 500-600hp) did 44K miles on track with wobble bolt without a problem. So it can not be that bad.Attached FilessigpicComment
