evo wheels fitment on audi
  • A1quattro
    • Jul 2006
    • 791
    hi the evos have 114.2 pcd ,we are 112 has anyone on here fitted any evo wheels on there ur/s2 poss by drilling /fitting new steel inserts to give correct 112 pcd
  • Kiku
    • Aug 2010
    • 497
    Should be the answer for you. Wheel pcd adaptive or wobble wheel bolts.
      just redrill the hubs
      • diesel des
        • 3896
        Yep I have my hubs drilled to take both stock Audi and 114.3 pcs rims so 10 holes in total. Means you don't need to mess with weird studs.
        • diesel des
          • 3896
          Like this
          • K Simmonds
            • Dec 2007
            • 7637
            That's the way it should be done, I don't like the idea of those wobble bolt's though I guess they'd do the job.
            A1quattro...what style Evo wheels do you want to fit ?
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • A1quattro
              • Jul 2006
              • 791
              I have been looking for a spare audi 16/17 " magnisuim wheel just to save some weight , cant find any cheep audi but lots of EVO wheels hence my thoughts of poss useing them . but as its just for a spare welst rallying I would use the wobble bolts [never seen them before ] I cant have 2 sets of holes in hubs as ive cut metal out so they are flower shape now
              • SE_30
                • Apr 2010
                • 1114
                • Home: England Current: Israel
                I'd not be using wobble bolts on a rally car... Wobble and Bolts are not two words that I like the sound of in a description.
                Stuart
                B2 90 quattro with boost
                • GazzaG60
                  • 4133
                  I got 3 bbs rs2 wheels 8x 17 5x112 et 35 doubt they would be the right type though. ideal spares
                  • varia
                    • 821
                    • Current: United States
                    this side of the water, there is a guy called jim green.
                    He is a very knowledgeable nice guy.
                    his very well built 90q (around 500-600hp) did 44K miles on track with wobble bolt without a problem. So it can not be that bad.
                      Wobble bolts won't work unless you put a 17mm+ drill bit through the Evo wheel bolt holes. Drill the hubs and run M12 bolts or studs, as others have said.
                      • A1quattro
                        • Jul 2006
                        • 791
                        that's fine as I already run with 112 studs all round
