You need to do a search, there are loads of threads about this
I know that 235/35/18s on 8.5J (et36 I think) will just fit on a coupe without rubbing. These tyres are the correct rolling diameter to keep the gearing and speedo correct. I had a 3mm spacer on front to clear the steering tie rod ball joint. Could probably have spaced a few mm at the back too.
Of course if you wan to go "stretch" there are more options
i run s2 running gear on my car. a flat arched b3 saloon.
I have 235 45 17 on the back on b5 s4 rims. no spacer is required. fits inside the arch so id say a coupe could do a 245 on the back with the correct offset.
fronts would need to be closer to the usual sizes and offset so maybe as above 235 on the front.
hard to say. everything I read said you gotta have spacers for b5 wheels. I don't front or rear.
THANK YOU ! just what I wanted to hear
I thought about getting 8.5'' at the front and 9'' at the back with 245 tiers.. but thats to big at the back maby..
I do have 18''x8.5 with 225 tiers on it now and that's just hideous..
On a coupe there is more room at the back than on the front.
Max size on the front is 245/35 18. Above that you need to modify the arches.
8.5J ET32 is the widest wheel you can realistically run with 245s without modifying the arches.
I had 18x8.5 with 225/40/18 et37 with 15mm spacers all round,backs was ok but fronts rub on spirited driving so 10mm spacers on front would of been better but I had kw3 coilovers and lowered it just above each tyre might of got away with some 225/35/18
Depends on the tyre as well... e.g. i had 8j 235/40/18 Federal 595-RSR which have a big shoulder and they scrubbed like a bitch and required cutting the front bumper.
Ride height also makes a big difference to wearing through the arch liners, if you have different springs/suspension on?
Koni tubes and some green H&R springs, nothing extreme
The Perfectionist
That doesn't rub in the rear?! Can you show some pictures?
I have a set of 8jx17 et40 bolero's that I want to fit on my B3, but have been told that anything above 215/40 will cause problems..
fronts yes I reckon 215/40's. maybe 215/45. et40 will be about right. towards the limit on edge of arch. I used camber bolts too to get them tucked in easier. can be done on stock bolts but easier on camber bolts. much recommended for getting close to the steering joint.
rears. I need to match the tyres sizes for the Quattro so at present the 235/45 is too big but doesn't rub. not so far anyway but would on extremes I think. it needs a 235/40 think to match wheel sizes and clear well. maybe 225/40 for the back.
comments on tyres not all being the same is correct. i have some 225/45 and they are basically the same as the 235's
I have the old type of struts with fixed bearing housings, so can't play with that.
I'm not afraid of the wheel sticking out of the arch as I had the wheels on before without tires. The steering joint will be a close call, even on 215's I think.
