wobble bolts
  • david1980
    • May 2014
    • 1029
    wobble bolts
    what are people's opinions on wobble bolts to fit 5x114.3 wheels to a 5x112 car
    yay or nay?
  • andyg plym
    • Nov 2006
    • 4646
    It's a no from me!
    It just doesn't seem right
    • LHD_Kid
      • May 2006
      • 3697
      Well....
      • sam80quattro
        • Oct 2006
        • 1496
        Seen them used hundreds of times perfectly fine. If they were never named wobble bolts they'd probably have done a lot better sales wise lol it's only actually the washer on the end that moves.. I'd use them if I had them lol
        • John.
          • 2619
          Sam, the name does make them sound a bit ropey!
          Personally I think why fit something that doesn't really fit?
          .......I have no experience of said bolts BTW.
          • gavs20v
            • Sep 2004
            • 3057
            I've used them before as have friends without any issue
            S2 Cabriolet.........
            • als2
              • Jul 2009
              • 809
              Snap....the wobble bolt nickname does them no favours and most people who have never used them say sounds like a bad idea, and tbh id agree with not using anything that wobbles!
              But they dont, they merely shift the taper and threaded part of the bolt so that they are eccentric thus making an adjustable eccentric bolt. Now we all know that the vertical load on the wheel is taken by the hub centric aspect of the alloy sitting on the hub and the driving force is taken care of by the clamp force generated by torquing the bolts ie alloy to hub. So the bolts are basically just providing the clamping mechanism.
              Ive used happily before, no issues and would happily again. Just my 2 cents.
              Al
              • david1980
                • May 2014
                • 1029
                do you have any places you'd recommend for them?
                and what car/wheels did you use them on al?
                • diesel des
                  • 3896
                  They should be OK. What I did was have all the hubs drilled and tapped to allow use of both patterns. Best of both worlds?
                  • david1980
                    • May 2014
                    • 1029
                    I have thought about that but its not an option at this time, maybe in the future we will see which is why I was thinking about the wobble bolts instead
