Tyre Opinions....
    Originally posted by dan_b
    There was a fairly long thread on here recently talking about tyre pressures and how one poster had the feeling that the car was "skating", and that the steering was overly light -this was caused by him running too high tyre pressures - I think he was running something like 42-46psi...
    I run mine at 36psi on a 17" wheel which seems fine to me.
    That was Robo
    • Keeper of The Kitten
      • Dec 2003
      • 2317
      I would say 36 on a 17" wheel is good as the aspect ratio won't be "too low" - but I wouldn't go lower on pressure. As I think I may have mentioned, I used to run just 28-30 on 17" wheels when I had my 80 (205/40-17) and it was a bad idea. The sidewalls were marginally shorter than the ones I have now (225/40-18) and the rims were egg shape! Ran ok though... Anyway I am running 38-40 on the 18" wheels and that suits the tyres reasonably well. I don't think I would go higher than 40 so Robo's 42-46 is too much IMHO.
      Michelin show the maximum recommended load on the tyre sidewall with a running pressure of 44psi - so it clearly isn't too much for the tyre, but it won't necessarily suit the car.
      Incidentally, regarding handling issues - if you use stiffer suspension, the tyres are worked harder, so it may be better to run lower pressure. Softer suspension doesn't work the tyre as much, so you can probably run higher pressure. Please note, I only say "probably" - tyres are always going to be a bit subjective.
      __MDC__
      Martin Cutting
