Originally posted by dan_b
Tyre Opinions....
I would say 36 on a 17" wheel is good as the aspect ratio won't be "too low" - but I wouldn't go lower on pressure. As I think I may have mentioned, I used to run just 28-30 on 17" wheels when I had my 80 (205/40-17) and it was a bad idea. The sidewalls were marginally shorter than the ones I have now (225/40-18) and the rims were egg shape! Ran ok though... Anyway I am running 38-40 on the 18" wheels and that suits the tyres reasonably well. I don't think I would go higher than 40 so Robo's 42-46 is too much IMHO.
Michelin show the maximum recommended load on the tyre sidewall with a running pressure of 44psi - so it clearly isn't too much for the tyre, but it won't necessarily suit the car.
Incidentally, regarding handling issues - if you use stiffer suspension, the tyres are worked harder, so it may be better to run lower pressure. Softer suspension doesn't work the tyre as much, so you can probably run higher pressure. Please note, I only say "probably" - tyres are always going to be a bit subjective.
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
