Tyre Opinions....
  • dan_b
    • Sep 2003
    • 3670
    Which model of Toyo - that's a good price
      Originally posted by mcandmar
      Toyos for €205, winner
      No probs mate.
      • mcandmar
        • Apr 2004
        • 5118
        T1S - going to go for these as i can drive up and get them fitted and balanced...
        Whats the deal with nitrogen filled Lighter weight or is there any other advantage?
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • dan_b
          • Sep 2003
          • 3670
          Get them at that price, you won't regret it!
          No idea why you'd need to fill road tyres with nitrogen - that's what they use to inflate F1 tyres with but can't see the point on the road...
            Nitrogen Tyre Filling Benefits...
            • Nitrogen permeates through the tyre 3 to 4 times slower than oxygen - tyres maintain pressure longer for better fuel economy, better tyre life, and increased safety.
            • Nitrogen reduces oxidation to tyre rubber and rims caused by oxygen in standard compressed air.
            • Nitrogen filled tyres run about 20% cooler than tyres filled with standard compressed air - tyres last longer.
            • RoscoS2
              • Aug 2004
              • 190
              Only £3 a wheel to get them filled with nitrogen, as jamo explained, there are a few benefits, also that when air is used to inflate, small particales of water also enter, which speeds up corrosion - not good. I'm sure in the long run it will make a slight difference...?
              Rosco
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                #22
                I always fill my tyres with gas that's ~80% Nitrogen.
                SS
                • RoscoS2
                  • Aug 2004
                  • 190
                  Failing that, good old butane calor gas does the job!! haha
                  • Keeper of The Kitten
                    • Dec 2003
                    • 2317
                    As I understand, Nitrogen filling results in less pressure variation due to temperature changes. That's why F1 teams use it, to try and maintain a constant running pressure and therefore maintain a constant balance in the tyres for the driver.
                    We tried it in F3 a few years ago (which didn't make a sod of difference to lap times AFAIK) but to be frank I can't see the point in using nitrogen in road car wheels.
                    __MDC__
                    Martin Cutting
                      • Dec 2003
                      • 2317
                      BTW, I am on Pilot Sport PS2 at the moment, 225/40-18, but I am now getting to a point where I can sensibly swap all four and I might try something else.
                      Think I need to get rid of a bit of toe-in as the outside shoulders are going on the fronts a bit (more on the LH but probably due to road camber and/or slow speed parking at work and home where all the turns are made with RH lock on the steering wheel).
                      Also worth noting, the pressures should be quite high in these tyres - certainly worth considering running at 38-40psi or the edges will wear out very quickly, and you won't be using the largest effective part of the tyre if you don't use some of the middle as well! I used to run tyres at about 30 (around 2 bar) but for wide-ish low profile tyres it isn't the way to go.
                      As I understand it the Michelins are far from the best all round choice but I've not had that much trouble with them. Perhaps I'll choose Goodyear or Toyo - but Toyo are very soft and short life aren't they? Fun but expensive?!!
                      __MDC__
                      Martin Cutting
                      • dan_b
                        • Sep 2003
                        • 3670
                        #26
                        I didn't find Toyos to be short life when I had them -in fact exactly the opposite vs. the Yokohama A-520s I used to have which I replaced and moved on to Toyos. I was getting about 3000miles out of the Yokos, got >10,000 miles on the same car out of the Toyos and they gripped better too. GoodYears are also giving me good wear rate.
                        IMHO 38-40PSI is too high a pressure for the S2, especially if you're on 17" or bigger wheels. You'll risk getting vague and light steering, reduced traction and brake power, plus a poorer ride.
                          • Dec 2003
                          • 2317
                          Ok, looks like Goodyear or Toyo are worth a look!
                          Tyre pressures, not sure I can agree Dan - if you use less of the working surface it isn't a great way to go (except in the cold or wet - deliberately using more camber to heat up a smaller area of the tyre is common in m/sport).
                          In fact, I'd say the opposite for lower profile tyres on 17" or more, you should actually be going for more pressure. The sidewalls tend to be quite stiff anyway and the pressure doesn't affect that very much, but the middle of the tread will virtually go for a free ride if the pressure is too low.
                          I've felt no obvious difference in ride or traction since moving to higher pressure, and evenness of tyre wear improves dramatically. Play with them a bit and see what you think. It's probably better to use a bit more up front due to engine weight, the rears can use less.
                          __MDC__
                          Martin Cutting
                          • mcandmar
                            • Apr 2004
                            • 5118
                            With the 40 series tyres i'm running 40psi front 38psi rear and all four are wearing evenly. Any less and they went squidgy and bent rims over large pot holes. Then again thats irish roads for you
                              • Dec 2003
                              • 2317
                              That's the other problem, and one I was advised on in the past. Depends on the brand of wheel (I think my OZs are fairly tough), but it's best to avoid transmitting too much load directly into the rim.
                              BTW, some of the roads over here ain't great either!
                              __MDC__
                              Martin Cutting
                              • dan_b
                                • Sep 2003
                                • 3670
                                #30
                                There was a fairly long thread on here recently talking about tyre pressures and how one poster had the feeling that the car was "skating", and that the steering was overly light -this was caused by him running too high tyre pressures - I think he was running something like 42-46psi...
                                I run mine at 36psi on a 17" wheel which seems fine to me.
