Hello, please tell me what could be the reason? If you accelerate and put the car into neutral, the revs drop to 400-500, and sometimes the car stalls.
A dip below idle speed after acceleration and neutral gear engagement.
Try giving the idle valve a good clean. Failing that, vacuum leak maybe.Nothelle S2 Avant
Urs6 plus project goneComment
Idle stabilisation is triggered by the idle switch on the throttle body, perhaps it's not closing or the connector needs a clean.Comment
Auto gearbox?Nothelle S2 Avant
Ok, I would check for vac leaks then try another ISV if you have a spare. After that a few other things can cause low revs and stalling like a faulty coil pack, spark plug, low compression, head gasket failure, timing slightly out etc. Just a case of working through things methodically.Nothelle S2 Avant
I am struggling with this on a 3A which uses the same ISV 034 133 455 B and I bought a new one from you know how in Berlin, made by Essen, it made a big difference to the stalling but not perfect. Does it do this when driving and coming to a stop? With the 3A I found it was the throttle closed switch not being triggered fast enough ahead of the damper due to corrosion in the spindle but the AAN uses a potentiometer like the ABY/ADU, part number 078 133 154 and this can cause the same fault, you need to check its position in measuring blocks using VCDS and the 2x2 adapter.Comment
