So sorry to the concourse brigade,I didnt paint the block. It doesnt make it any more fun to drive with a spangly bay.
Engine is 99% ready to go in. Just mounting the trigger wheel,but may leave this untill its in the car,so as to be sure the pick up is located away from everthing.
Blanked off the ISV hole on the inlet mani. Dont need that.
Just waiting on a 3b loom for all the connecters and a tps. I decided to have a seperate loom for the engine and aftermarket ecu. That way the ecu can do stuff like fan cut in point ect. Not sure yet whether to use a digital dash from the ecu or the stock instuments. This way I still have the choice.
Im not going to be fitting it perhaps untill later in the year,as space is tight at work due to us installing MOT automated test lane,and a bike MOT bay.
Ive been using the car regularly with no issues exept noticed a clonk from the rear and vauge gearchanges. As the MOT pit is built now I thought id drive it on to have a look. Its one of these
Way easier to use than a ramp,better light ect.
So put the car on to discover this...
It was trying to hold the rear diff,LOL.
It was brand new less than 3 months ago!!! Oh well. To be expected when running rwd only. Obviously pointless just replacing it so one cup of PG later I had a plan. gsf dropped up a new bush and i installed it with a 15mm spacer under it and the cup installed the other way up,so as to squish the bush and eliminate the up/down movement.An extra nut takes car of the free length of the bolt. Did both the diff mounts and both the gearbox mounts like this as well. Diff is now not moving anywhere,and there is still a bit of pliency so its not as vibey as say solid mounting them or polys.
Very pleased as mods like this cost nothing for a massive improvement.
