New member in need of help
  • Vinny
    • Apr 2013
    • 222
    Hi there I'm new to this I have just purchased a 89 coupe and when the diff locks on it judders and makes a noise when I turn can anyone help please...
  • irishs2
    • Apr 2009
    • 2455
    Thats how its supposed to work. When you lock the diff the rear axle behaves as a single simple axle, when you turn a bend one wheel has to turn faster than the other, with the diff lock on this results in a judder.
    Eric
    95 S2 Avant under rebuild.
    • Vinny
      • Apr 2013
      • 222
      Cheers for the reply eric .When I drive in a straight line it feels a bit gutless you have to give it loads of gas and still a bit juddery.when driving in a straight line should it perform as normal ?
      • irishs2
        • Apr 2009
        • 2455
        With the diff lock on, in a straight line the car should run the same. If the car runs fine with the diff lock off, then you might have a vacuum leak, the diff lock is actuated by vacuum, and maybe when you engage it, it introduces a leak into the system.
        It might be something like this pic:
        Eric
          what car is it? 10v? 20v?
          As above diff lock sounds as if its working fine.
          • Vinny
            • Apr 2013
            • 222
            I think it's a ten I'm clueless when it comes to engines but am willing to learn I know it a 2.2 non turbo on a g plate .I only got it last week I'm looking to get it insured today .I am also wanting to find a good auto electrician in and around the Cumbria area who knows these cars and won't spent three hours scratching his head !!
              haha. Yeah if its a 2.2 it will be a 10v.
              What issues do you have? There are some guys on here who are pretty handy with those kind of issues
              • Vinny
                • Apr 2013
                • 222
                Well that's something new I've learned already .it is all a bit confusing about b3, aby .as mine is a ninety not sure of compatibility of parts etc .the fan has been wired to a switch inside which I don't like , the windows are permanently live also back lights were not sealed properly and got water in now not working right .the car is for long term so will slowly go through it replacing everything .
                  OK bit of a run down:
                  All the coupe are a B3 chassis, just the later models post 1991 have the faclifted B4 front end on them. All coupes leak
                  There are loads of threads on the forum about the various common areas - rear lights are an easy one to sort out - there is a butyl mastic seal that gets old and dries out - you can replace it quite easily and a good time to fit the nicer looking later style tail lamps.
                  Windows should be live for a time after you have taken out the key, but IIRC should go off after you have locked the doors.
                  If the rad fan works correctly then the switch is probably just wired up to the radiator temp sensor so the fan can be switched on remotely from the switch in the cabin.
                  Have a look firstly at the temperature sensor on the bottom of the rad, as that is generally where the wires are tapped into for an override switch, or the fan relay
                  HTH
                  You will find answers to every question on here - someone will have been there and done it already
                  • benntenn67
                    • Jun 2009
                    • 859
                    All coupes leak
                    There was a dry one once
                    Hi Vinny & I have a roll of the mastic seal - oem Audi stuff & enough to do both rear lights - the windows stay live until the door is opened & ignition is off (unless of course the relays/thermal fuses are having a moment
                    Audi S2 Coupe 1995
                    VW Passat GL5 (hatch) 1986
                    Carrera Subway 8
                    • Vinny
                      • Apr 2013
                      • 222
                      cheers for the replies folks, just got my new toy insured today so had it on a little tour out ,it sounds mint it has a powerflow exhaust, my nephew works in a garage so took the opportunity to get it on a lift and have a look, rear sufram wishbones have seen better days so in future think i will replace them and seals!! there is a part leaking on diff which i could do with some knowledge on please i will post a pic of this and my new baby..cheers to benn tenn if your selling tape please let me know i would be very interested.windows on drivers side switches seem to be back to front right hand side dose passangers and vice a versa.. looks at fan today also and it has been hard wired via switch straight to fan on the of chance its had a different radiator in with wrong thermastat eg two pin three pin are these interchangeble.
                      • Vinny
                        • Apr 2013
                        • 222
                        really struggling to upload pic s how do you get them of your computer ?
                        • Acidburn
                          • 13459
                          use a photobucket account and link the pictures here
                          • Monkeymagic
                            • Mar 2012
                            • 3419
                            Mine is has been dry for 4 months.... For now at least
                            • Vinny
                              • Apr 2013
                              • 222
                              still struggling with photos ahhhhhh think pixels are to bog
