Hi there I'm new to this I have just purchased a 89 coupe and when the diff locks on it judders and makes a noise when I turn can anyone help please...
New member in need of help
With the diff lock on, in a straight line the car should run the same. If the car runs fine with the diff lock off, then you might have a vacuum leak, the diff lock is actuated by vacuum, and maybe when you engage it, it introduces a leak into the system.
It might be something like this pic:
I think it's a ten I'm clueless when it comes to engines but am willing to learn I know it a 2.2 non turbo on a g plate .I only got it last week I'm looking to get it insured today .I am also wanting to find a good auto electrician in and around the Cumbria area who knows these cars and won't spent three hours scratching his head !!Comment
Well that's something new I've learned already .it is all a bit confusing about b3, aby .as mine is a ninety not sure of compatibility of parts etc .the fan has been wired to a switch inside which I don't like , the windows are permanently live also back lights were not sealed properly and got water in now not working right .the car is for long term so will slowly go through it replacing everything .Comment
OK bit of a run down:
All the coupe are a B3 chassis, just the later models post 1991 have the faclifted B4 front end on them. All coupes leak
There are loads of threads on the forum about the various common areas - rear lights are an easy one to sort out - there is a butyl mastic seal that gets old and dries out - you can replace it quite easily and a good time to fit the nicer looking later style tail lamps.
Windows should be live for a time after you have taken out the key, but IIRC should go off after you have locked the doors.
If the rad fan works correctly then the switch is probably just wired up to the radiator temp sensor so the fan can be switched on remotely from the switch in the cabin.
Have a look firstly at the temperature sensor on the bottom of the rad, as that is generally where the wires are tapped into for an override switch, or the fan relay
HTH
You will find answers to every question on here - someone will have been there and done it already
Imola B6 S4 AvantComment
There was a dry one once
Hi Vinny &
I have a roll of the mastic seal - oem Audi stuff & enough to do both rear lights - the windows stay live until the door is opened & ignition is off (unless of course the relays/thermal fuses are having a moment
Audi S2 Coupe 1995
VW Passat GL5 (hatch) 1986
Carrera Subway 8Comment
cheers for the replies folks, just got my new toy insured today so had it on a little tour out ,it sounds mint it has a powerflow exhaust, my nephew works in a garage so took the opportunity to get it on a lift and have a look, rear sufram wishbones have seen better days so in future think i will replace them and seals!! there is a part leaking on diff which i could do with some knowledge on please i will post a pic of this and my new baby..cheers to benn tenn if your selling tape please let me know i would be very interested.windows on drivers side switches seem to be back to front right hand side dose passangers and vice a versa.. looks at fan today also and it has been hard wired via switch straight to fan on the of chance its had a different radiator in with wrong thermastat eg two pin three pin are these interchangeble.Comment
