not quite an S2...
  • davethedwarf
    • Sep 2013
    • 5
    not quite an S2...
    Greetings guys,
    a short while ago, i took possesion of a 1990 b3 coupe quattro 10v, and in my quest for information/ help, i stumbled upon this fine page.
    i very much hope that in time, my questions can be answered and my problems solved.
    Cheers in advance
    Lee.
  • Rikki Kitto
    • Feb 2010
    • 6276
    Sure you will get answers for all your questions it's a great forum with loads of knowledge and advice
    • davethedwarf
      • Sep 2013
      • 5
      Cheers Rikki, i look forward to extracting much knowledge!
      • Cottis
        • Feb 2011
        • 1448
        Welcome, I used to have a couple of these years back. They make produce a lovely engine note without a turbo getting in the way. Is it a KV or NG engine code? Hope it is treating you well. Mine never let me down, were super reliable but ate petrol without giving much in return apart from the best noise.
        • davethedwarf
          • Sep 2013
          • 5
          its an NG, i agree whole heartedly, its sounds gorgeous and the fuel consumption isn't a problem as yet. it is having a few running issues though, it has some sort of fuelling issue, it accelerates lovely in all gears, but seems to stutter/ struggle when maintaining a steady speed in whatever gear, the previous owner did a whole heap of work to try and fix this; cleaned out fuel tank, new pump/ accumulator/ filter, new dizzy cap/ rotor arm, new leads and plugs. the next thing he was going to try was the metering head, but i have no idea if this is the thing to do. aswell as this problem when in motion, is has an irratic/ hunting idle when stationary and i have to feather the throttle to stop it stalling sometimes. the issue does seem to get better once the engine is warm, but doesnt dissapear. :-( any thoughts?
          Cheers, Lee
          • K Simmonds
            • Dec 2007
            • 7627
            Hi Lee and welcome. Your idle/missing issue is almost certainly an air leak somewhere in the vacuum system, have a good look at the connections to the ISV and underside of the inlet boot, these engines hate air leaks. Ran an NG engine Coupe for nearly ten years and 60K+ miles, it only let me down once when the dissy packed up.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • davethedwarf
              • Sep 2013
              • 5
              cheers for the quick response!
              it had been suggested that that might be the issue, but as i'm quite unfamiliar with the NG, i'll have one of my mechanic mates to have a gander. if it is something as simple as an air leak, then that would be wonderful as i know the metering heads can be an issue. the car does smell quite petrolly once i've stopped the engine, like its overfuelling, is this one of the symptoms? also, i have no idea how to control the rear wash/ wipe, i think maybe a new stalk has been fitted but the front wash/ wipe stalk only controls the front, where should the rear controls be?
              Cheers, Lee
              • bluequattro
                • 2960
                Isv itself sounds like it to me
                I had a couple of Kv s that wouldn't idle and I d have to left foot brake to keep it running till warm, but it was fine otherwise
                Check the isv moves and it's not fitted with a crap Chinese copy with no insides(a customer bought one off eBay and it was cr*p
                • Val
                  • Apr 2008
                  • 630
                  • Country: Latvia
                  Cheers, Lee
                  This must be weared out around idle position.
                  Turn on google translate on this topic and start reading.
                  5vtq gte
                    welcome.
                    Firstly look at the vacuum circuits as suggusted above
                    Rear wash/wipe could be the motor, stalk or relay - the motors tend to get gunked up with old grease that congeals into sticky goop. Stalk contacts tarnish and wear out, and the relays can get dry solder joints. First thing would be to test the electrical connections at the motor and go from there
                    • jameswkr
                      • 538
                      I had an NG engined 90 quattro before my S2. I traced a wonky idle to the throttle switch ( hell of a job to change without taking the inlet manifold off ). You will have a problem getting to the ISV as well. Changing the air filter was also a pain... all that said, she sounded gorgeous and the chassis could handle a lot more than 136 bhp... Sadly she got t boned in a shunt after I had sold her..I nearly cried, all that TLC gone to waste.
                      • re2500
                        • May 2007
                        • 2185
                        Excellent choice! I also have a 1990 CQ 2.3E, i say have, i mean had....
                        ..too much time on this forum has cost me a few bob & turned her into an S2.
                        "Difficult is worth doing"
                        • davethedwarf
                          • Sep 2013
                          • 5
                          Thanks for the advice folks! Certainly gives me a few things to troubleshoot, hopefully the fix is easy and inexpensive!
                          Cheers, Lee.
