Wagner Inlet Install Questions
This is a sticky topic.
  • Lupo911
    • Apr 2005
    • 312
    Originally posted by Sonic
    WTF??
    there is only some minor cutting on the plastik needed, to clear the gaswire Wheel.
    If you are using different Motormounts like the ones from 034, they will lift up the engine a couple mm. Just put some spacers underneath the Motormounts to the the Engine back to the right position. But do not cut out the Bonnet!!!!!
    • s2_bo
      • Oct 2005
      • 6067
      #77
      Mine fitted fine without cutting the bonnet, I did have to remove some of the plastic trim but thats all.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • Lupo911
        • Apr 2005
        • 312
        sure thats how it should be!
        • Sonic
          • Jul 2006
          • 5514
          #79
          Originally posted by Lupo911
          WTF??
          Stock engine mounts, lowered as much as possible.
          Cut the plastic trim, still caught.
          12 hours before going to the 'ring it was take it all off, or cut.
          S2Forum.com Administrator
            There are two bonnet types, one catches one doesn't according to Pogea racing.
            Mine need cutting but then I do have a taller deck
            • PaulJ
              • Jun 2008
              • 253
              Thanks all, I'll have a better look in daylight,
              I'll drop my mounts down as far as i can go and look at raising
              gearbox on its mounts to see if that helps
              Cheers All
              1995 RS2 Nogaro
              1971 Lotus Elan Sprint
              1974 Lotus Elan+2S 130/5
              • lind4hl
                • Jul 2008
                • 2465
                Cheers All
                i would rather cut in the inside of the hood than changing engine/gearbox angle..
                • QuattroFever
                  • May 2006
                  • 1360
                  Originally posted by terrybullwon
                  Do you have the lenght of that belt?
                  sorry, not a clue...just luck that when i went hunting was the first one I picked up.
                  I knew roughly how many teeth it needed to be but no idea what car it was meant for or the length.
                  I didnt realise this hood cutting business till after I fitted a very frustrating home made accelerator cable which consequently came away at the first press with the bonnet shut.
                  Great kit but not bolt on, but then what bolt on kit ever is ...and could have come with some bolts and clamps I think, would've made the package a little more user friendly.
                  Volcano ABY coupe
                  Ant
                  • rash
                    • Oct 2007
                    • 68
                    #84
                    I know 5 people who got the Wagner/PKM inlet fitted in their S2 and everyone of them has cutted away some metal from the hood... ...why not... cut tidy and put paint on it properly - so no problem
                    you also have to cut away the lower mount for the original airbox if you use a tubular exhaust mainfold... who cares... only tiny cosmetic surgeries...
                    • GazzaG60
                      • 4133
                      i didn't
                      i used new track desity mounts too and they sit high. i removed the plastic and used a panel hammer to make a small flatter section bout 8cmx4cm. it required trimming of the cable holder too. throttle cable mods i did were to mount a network switch rack mount bracket to where the original throttle cable runs. cut original and use some brake pipe to fill the gap. i then put some piping round it to cover it all up. 18 months on...
                      you would never fit the airbox in with tubes and a turbo worth the tubes.
                      cutting a hole in the bonnet is really a shame.
                      • PaulJ
                        • Jun 2008
                        • 253
                        Bonnet update
                        Hi All
                        Got a little further with the install
                        Bought a long cable as suggested By S2_BO, Cut 300mm of outer cable
                        and made up metal sleeve to join the outers, threaded through new inner
                        and clamped at pedal with small connector block, Works a treat
                        Not yet cut bonnet but looks like not much needed
                        I did make the mistake of buying 034 street density engine mounts which
                        are a PITA, Why ooh why bother selling something which is not even the same
                        size as the original, Either that or my originals have sagged by about 10mm
                        If the flange where the manifold to throttle body was 25mm further down then
                        there would be no issues for anyone as there is plenty of room down there in
                        front of radiator, Anyone know where I could get a spacer then just use long
                        bolts and 2 gaskets
                        1995 RS2 Nogaro
                        • PaulJ
                          • Jun 2008
                          • 253
                          belt length
                          Hi, belt is 1025mm long x 13mm wide, Found this is the shortest belt
                          that fitted as I tried a 1000 and no chance of getting on PAS pump
                          hits bracket with a shorter belt
                          Cheers Paul
                          1995 RS2 Nogaro
                          • GazzaG60
                            • 4133
                            its the originals that sag. the new mounts are up to it.
                            i had to re-jig the x member and reweld the stub bracket on as it had no chance.
                            no cutting of bonnet needed. its one spot that needs a little flattening. you need to trim the black plastic cable holder, thats all.
                            think there are so many differences because of 1, the way the x memebr fits to these cars and 2 the diffgerence in old to new mounts.
                            • dreft
                              • Mar 2008
                              • 8
                              Hi, borrowing the thread for a question.
                              Im having bit of a trouble fitting my injectors in the 2 injector seats closest to the firewall. But so far I havent managed to get those two to "click in" like the other 3 wich mounted just fine.
                              Anyone else reported having trouble with this?
                              Audi S2 Avant 550hp Adolf
                              • Henkjan
                                • 1705
                                Just one question - the kit comes with a step-up hose to fit onto the intercooler inlet, im assuming ill need to cut back the samco and clamp a bit of tubing between the samco and new hose bit?
                                @Sonic, you are rigth, its just a Universal Part, because the most Guys are using different Turbos, its hard to make a Hose that will fit all
                                so what is the diamter of the standard hose between the turbo and the IC? is it 50? and the Wagner IC inlet is 70mm? and what sort of pipe is suitable to use to make the hose from the turbo fit to the IC connecting hose-bit?
