Well it's the one that works perfectly on my car!
Wagner Inlet Install Questions
This is a sticky topic.
with the s2 bumper you will find the pulleys are close to the cooler. make brackets off the corners of the cooler to the panels below the lights. make them rigid.
push the cooler as far forward as you can.
i have a nice round mark on mine from the crank pulley. happened in the accident.Comment
Has anybody had issues fitting the fuel rail/injectors? Mine dont seem to line up.
(ABY fuel rail, RS2 injectors, used wagner intake manifold)
Injectors in fuel rail and the front of the injector hits the intake manifold;
Injectors in intake manifold
Sold ABY-stockComment
I have fitted many Wagner intakes in past 4 years on ABY and never had that problem.
Are you sure intake you got is genuine?Danny
www.dnaautocare.co.ukComment
I have the Abt C5 bumper, IC just fits, don't think I can move it any further to the front. I guess I'll ditch the AC completely, has a leak anyway so hasn't worked for more than a year
no problems at all (std ABY injectors) on my carComment
crappy phone pic... in the yellow elips is where the aircon pulley rubbed against the IC
Attached FilesComment
Operator error
, fit the injectors all the way into the manifold, pull them forward and ease the fuel rail down, takes seconds and it pops straight on once you have done it once.
Thanks gents.
that pic henkjan is a different catcvh pint to mine.
mine was bang on central from the crank pulley. accident induced.
i have/had no aircon so no issue there. my air filter lives where that pump is.
can you make bracket to pull the cooler further forward at that corner?Comment
I just noticed that the pulley on the AC compressor caused some damage to the IC, probably touched it. I could not get close to it yet, so also no pix yet.
