Wagner Inlet Install Questions
This is a sticky topic.
  • prosty
    • Jun 2005
    • 1114
    Great! Thanks for the info. I'm not sure that the TB cable supplied with the car I'm doing this on is the right one. Will check that later
    2004 9-5 aero
    2009 Subaru Legacy Diesel
    1994 Toyota Supra Eurospec 6-spd LHD
    3-4 Audis in parts
    • dkw_dude
      • 555
      • Country: Norway
      #107
      Does the AAN fuelrail fit the Wagner intake?? Old thread/sticky but I'll try my luck here..
      Leif-Helge
      -91 S2 VEMS and Comp Turbo
      -12 B** 530XD Touring "S2 parts transporter, and daily driver"
        No I don't think so.
        • DJones
          • Jun 2005
          • 2020
          No the fuel inlet banjo thread needs to be cut off spun round and welded back on, well that's what I did.
          Darren.
            Or I've got a spare ABY fuel rail here
            • dkw_dude
              • 555
              • Country: Norway
              #111
              Thanks for the info guys. The ABY one is a direct fit? Does it have the FPR installed? PM me if you want to get rid of it
              Leif-Helge
              • EMU_S2
                • Oct 2013
                • 90
                • Country: Denmark
                #112
                aaight. so im about to buy an wagner intake manifold from some dude here in denmark. BUT!! i got a 3B engine. so what i got to know is that ill have to extend the different wiring for the TB. get a throttle cable that is extended, maybe cut away a bit in my bonnet, make a bracket for my radiator.
                but will i be needing another fuel rail?
                how should i connect the idle engine or whatever its called? (the cylinder just above the TB on a stock manifold)
                any other info would be absolutely terific now that its on its way.
                i have read this whole thread so far, and yet i still have these questions (might have missed something)
                Thanks in advance
                Chris.
                  I've got one on my 3B!
                  Idle stab valve gets plumbed in with a tube and a couple of small hoses which come in the kit. Fuel rail works fine.
                  • EMU_S2
                    • Oct 2013
                    • 90
                    • Country: Denmark
                    #114
                    hmm. thats the thing. im buying this: http://www.dba.dk/andet-biltilbehoer...id-1010773495/
                    not a complete kit.
                    he says its a wagner intake atleast. you might know better. allthough i know the IC is not.
                    but how about the throttle cable? and if i dont get that idle stabilisator valve kit. is there a place i can order it?
                      The spigot for the ISV is missing from that inlet manifold, on mine it is welded on near the dipstick bracket, I believe some were made without (for people running without ISV I guess) but not 100% sure..
                      Also there are some copies around, these are a bit taller and can cause problems closing the bonnet on URs. You're going to need the IC to TB hose with the take-off for the ISV, the metal tube, a 90 deg 20mm hose and the throttle cable bracket. I extended my throttle cable with an inner from a scooter front brake and an extra bit of outer and a joiner sleeve.
                        Here's the pic showing the ISV side.
                        • EMU_S2
                          • Oct 2013
                          • 90
                          • Country: Denmark
                          #117
                          I prolly gotta figure out something myself though yearh. How can i see if it is a real wagner intake or a fake?
                          And besides. Could you perhaps provide me with a bit more information and perhaps pictures of your mod to the throttle cable?
                            Here's a pic showing my engine, where the throttle cable has a slight kink thats where the outer cable is extended, I just slid the rubber tube over the join. Thenb I fed the new inner through from the interior and joined the original end on with a cable joiner (small tube with 2 screws used for joining electrical wiring) It's been working fine like that for a couple of years. SteveH has been promissing to make me a proper long cable but it hasn't happened yet
                            • Henkjan
                              • 1705
                              for LHD there is another Audi throttle cable you can use, part# should be on the Wagner website
                              and you'll need the hose from the IC to the IM as well, don't see that in the advert.
                              • GazzaG60
                                • 4133
                                i used a 19" rack bracket dog ear. a big one for 3U and a piece of brake hose. I sheathed it with some old brake hose.
                                worked perfectly for 2+ years. this time im gonna mod the 16vq one. it is longer to start with than S2 by the looks of it.
