Great! Thanks for the info. I'm not sure that the TB cable supplied with the car I'm doing this on is the right one. Will check that later
Wagner Inlet Install Questions
This is a sticky topic.
No I don't think so.Comment
Or I've got a spare ABY fuel rail here
aaight. so im about to buy an wagner intake manifold from some dude here in denmark. BUT!! i got a 3B engine. so what i got to know is that ill have to extend the different wiring for the TB. get a throttle cable that is extended, maybe cut away a bit in my bonnet, make a bracket for my radiator.
but will i be needing another fuel rail?
how should i connect the idle engine or whatever its called? (the cylinder just above the TB on a stock manifold)
any other info would be absolutely terific now that its on its way.
i have read this whole thread so far, and yet i still have these questions (might have missed something)
Thanks in advance
Chris.Comment
I've got one on my 3B!
Idle stab valve gets plumbed in with a tube and a couple of small hoses which come in the kit. Fuel rail works fine.Comment
hmm. thats the thing. im buying this: http://www.dba.dk/andet-biltilbehoer...id-1010773495/
not a complete kit.
he says its a wagner intake atleast. you might know better. allthough i know the IC is not.
but how about the throttle cable? and if i dont get that idle stabilisator valve kit. is there a place i can order it?Comment
The spigot for the ISV is missing from that inlet manifold, on mine it is welded on near the dipstick bracket, I believe some were made without (for people running without ISV I guess) but not 100% sure..
Also there are some copies around, these are a bit taller and can cause problems closing the bonnet on URs. You're going to need the IC to TB hose with the take-off for the ISV, the metal tube, a 90 deg 20mm hose and the throttle cable bracket. I extended my throttle cable with an inner from a scooter front brake and an extra bit of outer and a joiner sleeve.Comment
Here's the pic showing the ISV side.
Here's a pic showing my engine, where the throttle cable has a slight kink thats where the outer cable is extended, I just slid the rubber tube over the join. Thenb I fed the new inner through from the interior and joined the original end on with a cable joiner (small tube with 2 screws used for joining electrical wiring) It's been working fine like that for a couple of years. SteveH has been promissing to make me a proper long cable but it hasn't happened yet
i used a 19" rack bracket dog ear. a big one for 3U and a piece of brake hose. I sheathed it with some old brake hose.
worked perfectly for 2+ years. this time im gonna mod the 16vq one. it is longer to start with than S2 by the looks of it.Comment
