Wagner intake manifold to high? on my Urquattro 20v-90
I had this problem also. Didn't realise at first and ended up sticking the throttle at WOT
Thank god i'd just had my massive brakes fitted!!
It also rubbed through the nice paint job i had on the inlet manifold
Originally posted by RallyQuattro
Please help! what should i do?
At short notice this was my only solution besides taking the inlet manifold off. And yes, i had to cut through the plastic AND the metal on the underside of the bonnet.
It fits on my ur quattro with AAN engine, but just. There is a paint graze/mark on the underside of the body where a aluminum bracket was welded for me onto the top of the inlet manifold to hold the throttle cable hits, or did hit untill filed back.
I had no problems with it fitting on my 3b, i think i just removed a bit of the trim from the roof lining, slandered height engine mounts too..
Maybe you are using some higher ones?
