2.5TDi question
  • AndyP
    • 6049
    2.5TDi question
    Does anybody know what this does on an AAT 2.5TDi?
  • BRY
    • 3755
    It's a thingy in the sump.
    • Bedtimebear
      • Dec 2008
      • 90
      Erm......having a chat with the other half and we're thinking that it's an oil sump but when you look at the engine pics on Audi we can't really find the exact bit that you are on about it doesn't appear to be listed which is a bit strange as normally etka shows it but you can't flip the image around to show the underneath
      Project Little Gem - Pearl White Track Toy quattro
      • terrybullwon
        • Mar 2006
        • 8782
        whats on the block side?
        Chef
        • AndyP
          • 6049
          Thats where I got to looking at the FA, it appears to channel the oil drained from the head from one end of the engine to the other but I'm not sure why. On the TDi there is no windage tray so it can't be re-fitted, just wondered what the consequences might be?
          Looking at other pics of the S2 engine it appears that this has nothing attached to it, so I'm guessing it'll be fine.
          • Acidburn
            • 13459
            Could it be to move the oil to the front of the engine when its returned?
            • Jas11n
              • 5067
              Pop the part number into ATP within the FA, should tell you.
              Is it 046 103 145 ?
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • terrybullwon
                • Mar 2006
                • 8782
                maybe block it?
                Chef
                • AndyP
                  • 6049
                  Looking at this picture of Stu's 3B, there is nothing on the S2 so I assume it should be fine.
                  I'll try the ATP trick tomorrow and see what it says.
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    It's some sort of baffle for the crankcase breather. Will a windage tray fit with the long stroke crank?
                    SS
                    • AndyP
                      • 6049
                      Windage tray fit fine on the stroker, only thing I had to do was cut some holes in it to clear the ARP studs
                      • denniselbows
                        • 740
                        could it be simple to move the vent for the crank case out of the path of the oil thrown off the crank. May be the longer stroke of the deisel crank throws the oil straight up the vent. And they had to move it forward as there couldn't just extend it because of clearance with the sump.
                        never set your expectations to high that way you are never disapointed
                        • dubmeister
                          • 522
                          The part is the crankcase ventilation duct, so as said above, it could be there to deflect oil thrown by the longer stroke crank from the crank vent hole. Surely some form of deflector plate could be fitted/fabbed???
                          • Tom_
                            • Oct 2007
                            • 1301
                            • Country: Czech Republic
                            Little bit old topic, but could be used this diesel breather block on diesel engine block (aat) with oil windage tray and 7A oil sump? I forget to check it and assembled engine without this breather and before a while I remeber on this
                            Audi Coupe Quattro 2.3 20V
