Bluetooth speaker kits
  • Bluetooth speaker kits
    Hi geeks just wondered if anyone was into electronics and making thier own stuff, I aim to start making my own Bluetooth Speakers and am looking for a supplier of the parts to do this, any help advice or pointers in the right direction would be great
    I made more loudspeakers than my wife wants to remember
    for the easy part: BT kits can be picked up from fleabay or dx.com, or alibaba
    the before I write 4 pages of nerdy audio ramblings, a few questions:
    • where should they be going? living room? portable?
    • what's the budget?
    • what is your skill level in woodworking and electronics?
    • What size?
    • what are your expectations for the sound quality?
      As henkjan says if you answer the questions above. There are quite a few different kits around though
        Mucho Wifi
        Poco Hifi
          • What size?
          Placement could be anywhere around the house or even outdoors
          Budget is flexible but I think maybe £250 limit
          Skill level is moderate I can solder and use tools as I need to, woodworking isn't needed as I intend to use old items such as radios etc to turn into bluetooth spekars
          Max size speakers will be 5 inch
          Sound quality needs to be reasonable nothing spectacular maybe equal to £100 to £200 of the shelve speaker
            With the budget you have it might be worth considering https://www.mopidy.com/ with a decent DAC coupled up to hifi amp and speakers. Add a phatdac to your pi https://www.modmypi.com/raspberry-pi...CABEgIt-_D_BwE and get a second hand amp and speakers
              Hi Greg I intend to convert old equipment to be used as a Bluetooth speaker then sell not keep for my use, thanks for the links though
                If you want to use an existing design, then it should be for a speaker of approx the same dimensions as the new "box" you want to use. Both bass unit and crossover design are tied to that
                  Thanks for the advice guys now any ideas where I can buy these kits
                    battery powered or from wall socket?
                      could be both I suppose with rechargeable circuit perhaps
                        then you need to find a low power consumption amplifier (class D), that will run on 12V
                        I'll do search for some projects to serve as examples
                          Makes sense Rikki, so you're planning on buying up old kit adding bluetooth ability then selling on?
                          I'd suggesting having a look through on aliexpress.com as there is all sorts of kit on there that you could try.
                            Yes that is the plan seen some lovely old Bakelite type radios that are no longer working or repairable and thought why not up-cycle them
                            • #15
                              for the amp: look for e.g. Ta-2024 based kits, they have low power consumption and should run on 12V
                              project for a portable speaker on a boat: http://forum.zelfbouwaudio.nl/viewto...rdicht#p164231
                              (you'll probably want to use google translate, it's in Dutch)
